Question about Electrolux Vacuums
I own a Electrolux Discovery 1572E. The motor that operates the beater bar is out. The vacuum will come on, but that motor will not. The beater bar will not turn. Can this motor be replaced?
  • 113 Answers
  • yes but first try cleaning the brush then try the reset button.
Posted on May 01, 2015
SOURCE: Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 15, 2008
EwingElect
  • 276 Answers
SOURCE: beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
Posted on Mar 22, 2009
  • 70 Answers
SOURCE: Electrolux 1572E (Discovery II) How to remove
Remove the handle assembly by taking the big screw out and pull up on the handle. Remove the four screws where the top half connects to the bottom half. Two on the outside back and two on the inside front where the bag goes. You'll need a long phillips #2 screwdriver. Always have the power disconected. Pull up on the bag housing while twisting it side to side.
Good luck after you get in.
Posted on Aug 10, 2009
SOURCE: bissell 6579-2 bagless vacuum. Beater bar siezed
1. Uing the appropriate sized drift punch, tap out the steel axle rod which passes through the beater drum.
2. Each end cap houses a 608ZZ ball brg.
3. Check each brg for freedom of smooth rotation. Replace both if either is seized.
4. Replace with either 608ZZ (dbl shielded) or 608 2RS (dbl sealed) brgs.
5. Inspect and be prepared to replace the drive belt since it may have been damaged in the seizure event.
Posted on Sep 07, 2009
  • 694 Answers
SOURCE: The motor running the beater bar on ny Electrolux
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
Posted on Oct 16, 2010
Why won't the beater bar turn?
clean the stuff off the beater bar ends and see if it works .
Apr 27, 2015 | Electrolux Vacuums
How to install a new cord on Electrolux discovery model 1572E
un screw cover note wiring then reverse action taken
Feb 13, 2015 | Electrolux Vacuums
Beater not turning but belt good. beater motor not turning but turns manually
Hi Dan:
check both ends of the beater bar. Pet/Human hair, thread, strings and even dirt can really get wound up in between the plastic ends and the bar. It might look ok but it won't turn effortlessly. If you find that is the case, you might be able to fish the junk out but from experience it's just better to buy a new beater bar or roller part.
Mar 12, 2011 | Electrolux EL8502 Versatility Bagless...
Looking for top part of vacuum of 1572E electrolux discovery ll
You can order these, and other parts, at an Aerus Electrolux store. If the store is too far away, call and ask them to order one and ship it to you.
http://www.aerushome.com/storelocator/
Jan 31, 2011 | Electrolux Vacuums
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
My beater bar makes a noise and has a crack in the motor on the beater bar and is discolored--me thinks I need a new motor for the beater bar
Sounds like you're right. New motors are available at your nearest Aerus Electrolux store. They used to charge the same amount for selling the motor and letting the buyer install it, or for installing it in the shop. Worth checking in to.
Nov 08, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 1572E (Discovery II) How to remove suction motor cover?
Aug 10, 2009 | Electrolux Vacuums
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Beater bar stopped on discovery 2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=605948
Posted by steve6335 on May 18, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 possibilities that could be happening. Either the belt is broken of which you can replace the belt @ least one a year for proper maintenance or there may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum. Check both of those items and it should work unless you have a motor burn out – if you did there would be a burning smell. Feel free to contact your local vacuum cleaner dealer in your area.
Go Ahead. Use Us.
May 18, 2008 | Vacuums
Vacuums Logo
237 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
