How can I turn up brightness on clock. It's all dark
How do you get the display light on a bose radio to stay on
Do you mean keep it from going dim in a dark room? The settings menu has "Bright Hi" and "Bright Lo" adjustments you can make in ranges from 1-8 (Lo) and 8-10 (Hi). Check your manual under the heading "The setup menu" for very clear instructions.
Jul 03, 2014 | Bose Wave Radio
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
I have a 2007 Scion Tc and I have 2 problems.... When my car headlights are on, the light on the clock on the dash is off and when the headlights are off, the light on the clock is off so it's...
I can help with the clock light.
Normally, with the headlights off, the clock light (numbers) should be very bright so they can be seen during the day. The electronics designers thought you would only turn the headlights on at night so they made the clock numbers only bright enough to be seen in the dark (that is, they are dim in day light).
I like to drive with my headlights on (day or night) for safety. Therefore, I click my lights off occasionally, to see the clock (barely visible in daylight).
Part 2
I always find trouble shooting automotive electric a pain in the neck so I go to a shop that specializes in "auto electric". They will generally track down something this simple for about $25. It You can check if the spring fell out of your lighter (+ contact). Other than that, leave it to the pros - it is so much less of a headache.
-Mark
May 11, 2011 | 2007 Scion tC Coupe
I don't know how to make the Ipod go dark after it is on the clok
first set then alarm. then set your ipod lock time to 1 min. you can fine it on your ipod setting. hope i help you.
Jan 11, 2010 | Digital Products International Clok Smooth...
2009 lacrosse...compass, clock and milage lights sometimes stay real dim and then later pop up to normal brightness so I can read them...what goes ?
Starting car in garage turns on headlights which makes believe it is dark out and therefore dims dash lights. When car is out of garage it switches to running lights which allow dash lights to get brighter. I guess I should have figured that !!!
Jan 06, 2010 | 2009 Buick LaCrosse
The keys do not light up in the dark on my keyboard in the dark
I had the same question a month ago (with the Verizon version) and found that the actual problem was that I had the brightness turned all the way down. When I turned the brightness up to the second notch from the left, the keys lit up again. Although, I do not have it set to only turn on the keyboard backlight on in the dark. I have it set to always turn on when I slide out the keyboard. I also noticed that when I had the brightness turned all the way down, the lights on the front (aside from the touchscreen) i.e. the internet explorer button, would not light up either. That helped me a little with troubleshooting. Hope this helps!
Dec 26, 2008 | HTC PPC-6800 Smartphone
Want to change LCD brightness on Clock Radio
you could try to internally change the brightness, but unless you know a lot about circuits, I wouldn't mess with the internal wiring.
Nov 12, 2008 | Audio Players & Recorders
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
175 people viewed this question
 Grubhead
Grubhead
