Question about Maytag Performance MHWE500VW 4.0 Cu. Ft. Front Load Washer - White
Door wont latch on my maytag 5000 front loading washer
When closing the door the latch does not work. How can I fix it?
    Genius:
  • Maytag Master
  • 1,585 Answers
Door inter lock also door strike do both
Posted on Apr 27, 2015
    Top Expert:
  • Maytag Master
  • 10,875 Answers
Replace the door latch
Posted on Apr 26, 2015
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Front loading maytag washer door won't open. Help!!
Remove the lower front panel.Reach up inside near the latch. Feel for a ring tab. Pull it down firmly while pulling on the door.
Then open the cabinet and check all the wire connections in the latch circuit. Check the wax motor ohms. The wax motor probably needs replacing.
Apr 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Door wont latch shut
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Error Code LO
latch open it means your latch on your door is not connecting It happened to me when I switch the door to open the other way your washer wont start or will stop mid cycle if the connection isn't made it is simple to fish hopefully you haven't already paid for someone to come to fix it :)
Apr 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
My new front loading washer is not spining. It is 3 months old. We have a 12 month warranty and labor
call whirlpool customer service, they own maytag now, you will be covered under warranty.
Mar 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah8700A
ds - means that the door is open while the washer is running sometimes this can be easily fixed by opening the door then closing it and pushing it pretty firm to make sure it latches.
If that doesnt work there very well could be a problem that would need to be fixed by a service repairman you can call Maytag USA Customer Service @ (800)688-9900
hope that helps.
Jan 27, 2008 | Maytag MAH8700A Front Load Washer
Maytag door wont lock and go into spin cycle
You will need to replace the door interlocking device.
Oct 26, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Performance MHWE500VW 4.0 Cu. Ft. Front Load Washer - White Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
