Question about Craftsman Garden
I have a craftsman Lt 1000 21 twin hp tractor . I engauge blades they hesitate to turn on . Once they are on I start mowing in speed 2 or 3 then they lose power to a point where they just don't turn
    Top Expert:
  • Craftsman Master
  • 51,545 Answers
Either your battery is weak or the belt needs replaced
Posted on Apr 26, 2015
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Craftsman GT 5000 Garden Tractor, 25 HP,
Depending on your engine.. Briggs and Stratton or Kohler there are 2 different seat switches that are used to power the PTO clutch. The seat switch can cause the PTO clutch to disengage anytime there is not at least 70 lbs in the seat.
The PTO drive wiring has a 30 amp fuse in it. If by chance a stick went through the belt and tore off the wires at the PTO clutch (Common failure) even after you repair the broken wire you still need to replace the fuse.
Check the PTO clearance gap. It should be 0.012 dis-engaged. Any other value and the clutch will not work correctly. Adjust the clutch if necessary.
There is a 2 pin Pigtail just off of the PTO Clutch that you need to check for voltage at the connector. Probe the back of the wires if you can and your looking for 12V DC under the following conditions.
BRAKE ON or tied down
KEY ON
SEAT (Briggs and Stratton engine only) Someone needs to be sitting on the seat.
Then Pull the PTO Switch out. You should hear the PTO Clutch CLICK. If you hear the click there is no need to check voltage. The PTO switch is a multi function switch and it is quite possible the PTO switch failed. I doubt that the PTO Clutch has failed as they normally give you some kind of noisy indication that they are failing and don't fail straight away.
So.. In short
Check PTO Switch (Red wires) to usually red or brown thru the switch
Check 30 amp fuse
Check PTO clutch wires near PTO clutch (They get torn from something traveling through the pulley)
Check PTO clutch clearance at 0.012
Check Brake switch for an audible click as you depress it some distance No click.. possible bad switch
Listen for Seat switch Click as you slowly add weight to the seat. No Click or any click and it can still be suspect due to the Briggs and Stratton installed engine ones have more than one function.. Ignition and PTO clutch power.
The actual wiring diagram is on page 35 of the owners manal that can be found here:
http://www.managemylife.com/mmh/owner_manuals/27245/CRAFTSMAN-Lawn,-Tractor-L9910386?brand_name_search=917273023
Lastly... check each of the mower deck blade bearings. A seized bearing can cause PTO problems.
Hopefully you have enough information to solve the mystery. If not just respond here and I will help you.
Thanks for choosing FixYa.
Kelly
Posted on Oct 07, 2010
Testimonial: "Kelly - Your troubleshooting info helped me determine the PTO switch, mower belt and 30 Amp fuse were good. Solution: New battery fixed it. Thx! - Tom"
  • 6468 Answers
SOURCE: I have A craftsman Model 917.273470 with a Kohler 20 Hp V-Twin. It will run if I spray gas in the carb. Drained old fuel, replaced fuel filter, checked gas flow into carb with pressure guage, Cleaned
check the solenoid on the bottom of the carb check for movement and power if it moves and has power open the carb and clean it
Posted on Apr 19, 2012
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Ok i have a problem with lt 1000 craftsman lawnmower. the tractor starts up runs great just when you put in gear or try to put blades in motion it shuts down can someone plz help
check for a safety switch near your shift handle for the gears . most have a kill switch for when your mowing and go to drive in reverse with the blades on . when you go to do this it puts the shift handle against a metal switch that closes a normally open circut that ends up grounding the coil to kill the engine .. easiest thing to try and dont cost to try . is to unplug this ( temporary ) my mtds have 2 wires not sure if craftsman has these or not . but if so just unplug it and it should work and run like normal if this is what the issue is .
Nov 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower mows graet for 30 mins then starts to load
Yes you need to replace the needle and set in the carb.
Aug 23, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman DYT 4000, 24 hp 48" deck. While I was mowing, the blades stopped turning, started again, and then stopped. I shut down, all looked OK, tried to start and nothing. No click, nothing. Any ideas?
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Jun 12, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
93 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
