Question about Samsung CLX-3305FW Color Laser Multifunction Printer
My printer says scanner locked and gives very loud cranking noise when started.
  • 1 more comment
  •  johnny rebel
    johnny rebel Apr 27, 2015
    after reading about your printer,here is what i would do because it is 3 years old,disconnect all wires ,uninstall all printer programs and printer from your comp,(start fresh),plug printer back in,add needed software,update and try again,if it doesnt work,contact samsung and talk to them,otherwise,toss it out and get a new one
  •  johnny rebel
    http://www.samsung.com/us/support/owners...
  •  johnny rebel
    http://downloadcenter.samsung.com/conten...
  • Samsung Master
  • 1,915 Answers
If this is a new product out of box, then likely the scanner is locked. If this is a printer that has worked in the past but now does not and has not moved, then probably something in the scanning assembly is jamming.
Posted on Apr 27, 2015
Testimonial: "It is almost 3 years old and this problem first occured little after the guarantee was ended. I read somewhere that there would be some sort of lock/unlock switch but cant find any"
    Top Expert:
  • Samsung Master
  • 10,875 Answers
Read your manual
Posted on Apr 26, 2015
Testimonial: "the manual just says that I should contact the service center.. and they instruct to update the drivers.. so not much help there.."
  • 1 more comment
  •  johnny rebel
    go into control panel,then find your printer,then right click on it and click on properties,then go to drivers and then update drivers
  • Mikko Saarenp
    Mikko Saarenp Apr 27, 2015
    No, I mean I already updated the drivers but it didnt do any good
  •  johnny rebel
    then roll back the drivers and download again
My Canon MG8120 all-in-one makes a loud noise when copying (not when printing). How do I fix it?
Dear
from the question I understand, the scanner move to right and during return it starts noise.
The problem with scanner assembly, It might be dust accumulated on gears, the scanner belt might have loose or the grips of the belt has worn out. Proper cleaning and lubricating the moving parts may overcome also if the belt worn out it has to be replaced.
In case of at home position it gives noise then the home position sensor may dirty/dusty, it has to be cleaned.
thanks.
Feb 15, 2015 | Canon Pixma MG8120 Wireless Photo...
My scanner won't copy, all I get are black lines
Something could be electrical/mechanical mistimed now in a mechanical way dirty microswitches that have not give a break on the right moment to stop the scanner and has damaged something what has to made the loud noise .
Keep in mind your safety by working on high voltages and also mechanical recovery.
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%201815dn%20Service%20Manual.pdf
Aug 11, 2017 | Dell 1815dn All-In-One Laser Printer
Won't scan Makes loud noise
The scanner is probably locked. there will be a sliding lock somewhere on your scanner that you will need to unlock before you can use the scanner. If you can provide me with the model number of the scanner I can see if i can find a manual for you that will tell you where the lock is.
Mar 07, 2011 | Office Equipment & Supplies
WHILE THE PRINTER IS WARMING UP THE INK CARTRIDGE HOLDER WILL MOVE TO THE LEFT AND START TO MAKE A LOUD GRINDING NOISE. GET A MESSAGE TO TURN OFF AND CONSULT MANUAL. I DON'T HAVE A MANUEL. JOHN H
Hi!
On the scanner area look for a switch on the side or front that indicates lock position. You may need to lift the scanner up if you don't have the switch near the scanner bed. Make sure that switch is set top unlock. This is a feature for this type of printer to protect scanner part when transporting device.
Hope this helps.
Dec 13, 2010 | Epson Stylus RX580 InkJet Photo Printer
My Samsung scanner says "Scanner Locked" What does this mean. It makes a loud clicking noise like it is about to breakdown. juliakrebs45@yahoo.com
If you look into the paper output of the printer you find a green lever. Pull it to the front. Open scanner lid and check the position of the lever.
Restart printer by switching off and on again.
Oct 20, 2010 | Samsung CLX 3160fn All-In-One Printer
Epson SX100 Scanner makes a loud clicking noise!
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Apr 07, 2010 | Epson Office Equipment & Supplies
My scanner makes a loud noise on start up what is it ?
It is normal for your Epson scanner to produce noise on startup as it calibrates the motor that moves the scan mechanism when powered on. But if this is too loud than normal, it means that there may be already a problem with the motor and must be replaced if it wouldn't give out quality scans. Otherwise, it is working normally.
Nov 06, 2009 | Epson Perfection 1660 Photo Flatbed...
My scanner :makes a loud noise when trying to scan or copy
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I need more information to offer a definitive solution, but I can give you some information that might help diagnose the problem.
Unless you forgot and tried to use it locked…then unlocked it after, it seems unlikely that changing the ink could directly affect anything related to the scanner. So especially if it still scans and now just makes more noise then before, we can reasonably say it isn’t a faulty locking mechanism and that the gears are probably not stripped, which would either stop it or not. So you’re looking at either something simple like the gear assembly being dry, shifted slightly, etc. or the safety by the lock that makes noise to tell you the device is locked is stuck somehow. The one can be tested by removing the little plastic safety that makes the noise when the scanner is turned on and locked; the other you might be able to test with some WD40 and see if it runs quieter.
Aug 24, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
HP 7410 Scanner Failure
Sorry, you have a bad scanner assembly which will cost more than a new printer.
Jan 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Changing ink cartridges?
I have a dell printer, scanner, fax ect.
The printer and scanner won't work now. Keep getting message, " hardware errpr 0502, when printer starts up, gives a loud click noise.
How do I fix?
Mike Murphy mmurphy8015@yahoo.com
Jan 04, 2009 | Dell A940 All-In-One InkJet Printer
Samsung CLX-3305FW Color Laser Multifunction Printer Logo
195 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
