Computers & Internet Logo
Tom Palmer Posted on Apr 26, 2015
What I need is a tutorial of the desktop. I am totally ignorant of the top keys ands their function. Can you help?
Casio te 2200
Hi Good Day!
Before you reprogrammed it, check everything first,
if there is a reset setting, try to use it before you reprogramming it.
Change recite information from previous owner name
Esther:
The exact functionality you are requesting is located on page 52 of the Casio TE-2000 user manual. Pages 48 through 55 are a good read for you as well. You can access the manual at this location:
http://support.casio.com/en/manual/006/TE-2000_EN.pdf
Specifically, you will be changing the store logo and message header information to reflect your current store. The process is rather straight forward, and only requires about 5 to 10 minutes of work on your part.
Specifically, you'll need to decide on a few things first:
  1. Do I want a Graphic Logo?
  2. Do I want a Logo Message?
  3. Do I want top print a message at the bottom of the receipt?
Those three questions will help you program your unit. As the instructions on Page 52 outline, you'll need to insert the PGM (programming) key into the machine, and then do the following:
  1. PGM Key, turn to Program
  2. Press key '3'
  3. Press key 'Sub Total'
  4. Enter: '2122'
  5. Press key 'Sub Total'
From there, you have to enter a special code made up of the first 3 questions:
In your head, start at 0, and then add:
  1. If you wish a Graphic Logo: Add 0 (in your head)
  2. If you wish a Text Logo Message: Add 1 (in your head)
  3. If you wish to print a commercial message, Add 2 (in your head)
  4. If not, just add 0
  5. If you wish to print a bottom message, Add 4 (in your head)
  6. If not, just add 0
Now, take that total (whatever it is), and enter it. So, if you want a Text message AND a commercial message at the top of the receipt, but no bottom message, it would be: 1 + 2 + 0 or 3. You would then enter '0000000' (that's 7 0's). So, that would be '30000000' You then press the 'CA /AMT = /TEND' key. And then 'Sub Total'. From there, you can program your message following the instructions.
I know it can sound confusing, but these are just ways the machine understands what exactly you want it to do. Please refer to the user manual, as it outlines the exact process you need to do. You will also need to refer to the character code table in the user manual (on page 54) just to be able to enter text as it is.
I hope this has helped,
--Phillip
I need to resset all the gt on my sharp xe-a40s
They don't normally allow you to do that as it is a security feature to stop your staff from stealing. They are referred to as NRGT (non re-settable grand totals). Normally you just ignore them if you don't need them as they are not involved with your daily totals. Is there a reason why you need them reset?
2helpful
I have acquired an old casio 240 cr and need to reset all the totals can you tell me how I do this please
Great old machines. The 240CR is only simple, so you just turn the key to Z mode and press CASH to re-set the report. The grand total (GT) may not reset because it is usually a security feature, but you don't need it. Just ignore any GT on the report. all other totals should be cleared and if you do it each day, you'll get the figures you need.
If anyone needs more information, the 240CR manuals are here:
Casio 240CR User manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_240CR_operators_manual.html
Casio 240CR Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_200CR_and_240CR_and_PCR-360_and_PCR-365_and_PCR-465_service_manual.html
I just bought a Casio PCR T275 cash register and would like to zero out the "Z" report. Can you tell me how?
Try turning the key to Z mode and press CASH. That should clear the main report except for the grand totals which can't be reset. Just ignore them as they are not needed for daily reporting. If you want to remove the GT from the report, there is usually a setting. See how you get on. -----------------------------------------------------------------------------------------------------------------
If anyone needs more information, the Casio PCR-T275 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T275_users_manual.html
4helpful
2answers
Bios password removel of Dell Optiplex GX280
If you don't know the BIOS password, and need to access it - you'll have to unplug the AC power then open the case and remove the lithium "coin" or "button" battery from the motherboard. Wait 5 - 10 minutes (allows the capacitors to discharge) and replace the battery. This will RESET all BIOS values to default.
Restore AC power reboot. Enter the BIOS and change the values as desired. To access the BIOS, Press the F2 function key repeatedly during boot sequence. You may need to plug the USB keyboard into a different USB port if it doesn't let you in to the BIOS page.
I hope this helps & good luck! Please rate my reply - thank you.
2answers
Show subtotal at finlist
Please try this:- go to PGM-3 select key features select function key- hit sub total see detail functioning of sub total. if you find any link delete it and hit esc.key till you reach in original mode .
4helpful
Function keys Operations Teclado Intel A27982
there is a row of keys at the top of the keyboard labelled F1 to F12
RE: Recovery Disc
it's on the main screen..under My Computer..
Grand Canyon Tech
Grand Canyon Tech
