Question about Guillemot Hercules eCafe EC-1000W 10.1-Inch Netbook - Up to 6 Hours of Battery Life (663296415172)
Why is there a piece of string at the bottom - Guillemot Hercules eCafe EC-1000W 10.1-Inch Netbook - Up to 6 Hours of Battery Life (663296415172)
    Top Expert:
  • Guillemot Master
  • 45,451 Answers
Show us a picture of it . it could be the little helper to replace the battery ,tho usually tucked away inside when closed .
Posted on Apr 26, 2015
How to change string?
If you look at the bottom of the string holder (flipping the machine over) there should be either two tabs on the side across from each other that you press and pull, OR a twist and pull. There are several pieces, the inner piece that the string comes on has a hole that the string goes into to hold the string in place (needle nose pliers--press into hole). Then there is an arrow on the string holder, just wind the string in the direction of the arrow (does not have to be perfect) until you get enough on the holder. Now, hold the string so that the spool does not unravel--feed the end through the hole(s) and replace parts as they came off of the trimmer.
I hope this helps.
Feb 09, 2016 | Garden
Need to change the weedeater line.
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Sep 29, 2010 | Homelite Mighty Lite Lawn Trimmer
How to build a wooden pyramid frame for school children, 2metres on each length of base.
cut 4 pieces of 2x2 to1.5 inches short of 2 metres. lay them out end to end to form a two metre box. it can only work one way. then take string from corner to corner to find the center, making a crosshair. then stand a level rod at the centre to the desired height and fasten equal length lines from each corner to the peak. using a compound mitre saw, place an angle finder at the bottom and top corners to give you the angle to cut your piece with the saw set at 45 degrees, to give you your compound miter for the top. just set the saw blade to line up with the angle finder to get the bottom cut. the length of your "tight" string line frome corner to peak is your length of "hip" piece
Mar 10, 2010 | RTO M-D Building Products Carpentry &...
I sucked up a long piece of string, and it rolled around the bottom and smelled like burning. The piece of string is gone, but the motor doesn't sound like its engaging. Is this going to be expensive? Can...
flip the vac over take off the bottom cover plate to expose the belt and see if it still actually on the shaft, more than likely when you tried to run the vac while the string was wrapped around the beaterbar it caused the belt to either snap or stretch out so replacing the belt should bring it back to life without your having to spend more than a few dollars for spare belts and you do need to have some on-hand when they wear out
Feb 19, 2010 | Bissell CleanView II Plus Upright Bagless...
We have purchased a mastercraft plumb bob but can't see how the string attaches to the bob. The brass cassing is solid with a hole through the removeable botoom piece. Where does the string attach?
consult the owners manuel. or remove the removable bottom piece push the string through and put a double overhand knot on the string that is on the inner side of the removable bottom piece.
is this a trick question?
Dec 21, 2009 | Garden
Replacement of Cutting Line! How to do? anneodello
Jim
Oct 21, 2009 | Black & Decker Garden
How do you remove the line feed to replace with new. Is is scred on or does it have a lock washer
It should be screwed on. There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
Jim
Oct 17, 2009 | Craftsman Convertible 25cc. Gas Line...
How do you wind replacement line to the Poulan Pro String Trimmer?
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How do i restring the Ariens st 622 string trimmer
Cut two pieces of 18" commercial grade line - one to mount on each side. Look at the series of holes, two on bottom of rotating head, two immediately above but on outer lip of plate. Go up through the bottom two holes, even up your piece of line (like when you are putting in a new shoe string in a pair of shoes) and cross over then out through the top two. All done. If you are using an adequate grade of commercial line you can trim for hours over the roughest of stuff without worrying about restringing.
May 03, 2009 | Garden
Guillemot Hercules eCafe EC-1000W 10.1-Inch Netbook - Up to 6 Hours of Battery Life (663296415172) Logo
65 people viewed this question
Top Guillemot Computers & Internet Experts
micky dee
Maxx
Level 1 Expert
Avishek Samaddar
Avishek Samaddar
Are you a Guillemot Computer and Internet Expert? Answer questions, earn points and help others
