Question about Invicta Watches
Invicta venom reserve how to open back for battery replacement
    Top Expert:
  • Invicta Master
  • 51,191 Answers
Take it to walmart and have them replace battery
Posted on Apr 26, 2015
My invicta reserve Zeus bolt stopped working after not wearing for a little while and now I tried winding back up and it doesn't want to work
Most Invicta Bolt Zeus watches have a quartz movement and require a battery. I'm not sure there is any Zeus with a mechanical movement that needs winding. A jewelry store should be able to change the battery for a small fee if that's what it needs.
Mar 21, 2016 | Invicta Watches
How to remove the band on the Invicta venom reserve
If you are talking about removing the entire band from the case, the Venom uses 2 spring-tension pins on each side, both of which must be released from their holes in the case to free the band. it is a tricky, hard to see procedure, even for a jeweler, but it can be done. I recommend taking the Venom to the jeweler the first time and letting them show you what the attachment looks like. This would make it easier for you to try yourself in the future without scratching the case or becoming too frustrated.
If you must try this yourself, be patient and use a small tool like a mini screwdriver to release the first pin via the small gap on the underside of the band, and then look for the 2nd pin which is further back. A small flashlight may help you see the pins. Then repeat on the opposite end of the band.
Putting the watch band back on the case is somewhat easier, still requiring patience and several tries. Don't lose or damage the pins.
Sep 29, 2015 | Invicta Watches
Looking for an online invicta intrinsic settings and modes
INVICTA WATCH HAS A TOLL FREE SERVICE.HERE IS THE 800 NUMBER 800-327-7682 I THINK THEY CAN PROBABLE SOLVE YOUR PROBLEM FOR YOU.HAVE A NICE WEEK.TLT
Nov 15, 2014 | Invicta Venom Quartz Multi-Function Rose...
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
Feb 19, 2013 | Invicta Reserve Subaqua Venom Swiss Quartz...
I have an Invicta Venom #6111 with Poly strap. I want to put a Stainless steel ******** instead. How do I remove the caps covering the Screws holding the ********?
The caps are just for decoration. They dont cover anything. To remove the strap, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Reuse the pins with the stainless band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!
Oct 24, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
How do you remove links from the subaqua venom
Find how to remove or add links here: Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
Apr 25, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
Watches Logo
203 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
