Question about Poulan Garden
How do I removed the head on a poulan pro push weed trimmer
Instead of re-writing the basic instructions, here's an example:
http://www.answers.com/Q/How_do_you_remove_a_trimmer_head_on_a_troy_bilt_TB575EC
Posted on Apr 26, 2015
Saw attachment will work but weed trimmer attachment will not turn
check that the trimmer attachment is fitted properly on the shaft as it appears the the shaft drive is not engaging in the head
May 23, 2015 | Poulan Pro PP338PT 8 33 cc Gas Pole Saw...
How to remove head for poulan pro push trimmer
same as any gas motor remove the housing around the top and then take head bolts out .but why do you want to take head off . there might be easier fix .
Apr 26, 2015 | Poulan Garden
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to kno what the item number (so I can order) the line tensioner on my Poulan Pro Link line trimmer---PPB 335. It is a small plastic trimmer head cover. Do I have to order the whole trimmer head?
Your string head is part number 26 in the diagram. Home Depot's Garden department has a wide variety of parts including universal string heads and heads for Homelite, Ryobi, etc. and possibly one that will fit your machine. A lot of these trimmers have Poulan engine and trimmer head parts. See if you can get the complete assembly off the trimmer (if you haven't already) and take it with you to the HD and match it with a new one. The price of parts from an online supplier plus shipping will be almost as much as a complete replacement head. If you shop Ebay, there are literally hundreds and hundreds of weed trimmer parts on there and some good deals to boot.
http://www.mowerpartsweb.com/MANUALS/POULAN/PPB335.PDF
May 02, 2011 | Garden
Shaft heating up next to trimmer head- smoking polan pro150- and how to remove head for service
You can wrap a rag around the threaded end of the string head shaft after removing the bump knob to hold in place while turning the upper part of the string head counterclockwise to remove. Then you can do the same to remove the metal shaft adapter nut above that, exposing the flex shaft in its entirety.
Aug 14, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Can not adjust carburetor
Yes...they have them on Ebay. Normally you won't be able to get one from a small engine repair place or dealer unless you're "in" with them. You can make using a 22 gauge-18 calibre electrical connector. (Quick disconnects-female) They need to be female spade terminals and you can stick um on the end of a screw driver and then push them down over the round-splined heads of the L and H adjusting needles on the carb. Probably have them at auto parts store....if not Radio Shack.
Jul 12, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
My husband took his Poulan Pro 31 cc weed eater/trimmer apart and now needs an engine diagram to put it back together. Where can I get a downloadable one ?
Go to the Poulan web page http://www.poulanpro.com/node6556.aspx and enter the model number of the string trimmer. If the trimmer is a Weed Eater brand (owned by Poulan) then go to this page http://www.weedeater.com/node6507.aspx. I think you can also locate older model manuals in their archives.
Apr 10, 2010 | Poulan Garden
Do not know how to correctly string so string will come out as it is supposed to on my poulan pro weedeater, do not have directions
There are five ways to change trimmer line depending upon the style of trimmer head on your unit.
The first style has a locking tab on the side of the trimmer head that must be depressed while the lock ring is turned counter-clockwise. This will remove the cover and give access to the spool which can then be pulled out, rewound with the line (winding in the direction of the arrows on the spool), and re-installed.
The second style requires lining up the marks on the bottom of the spool tap/button assembly and firmly pulling straight out on the tap button. This pulls the spool assembly out so it can be re-wound and inserted back into the hub assembly.
The third style requires pushing in and down on the two locking tabs on the side of the trimmer head. This will remove the cover and give you access to the spool.
The fourth style of trimmer head is the Centrex. Remove the cap on the bottom of the head by unscrewing it. Remove the guide ring and remove the spool from the unit. Cut a 25ft length of line and insert one end into the center cavity of the empty spool. Feed the line into the spool, leaving 4-6 inches unwound from the center of the spool. Reinstall the spool, guide and cap, making sure the notch in the guide is facing away from the spool and the line is in the notch.
The fifth style is the fixed line cutting head. This style cutting head uses a pre-cut piece of cutting line. After removing the worn line from the cutting head, insert the precut piece into the positioning tunnel leaving an equal amount out each side of the tunnel. The ends of the line can then be inserted through the exit tunnels.
Oct 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
78 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
