Question about Facebook Apps
My facebook is not working
It is saying Another instance is running, Configuration system failed to initialize
2 Suggested Answers
bumdrew
  • 397 Answers
SOURCE: whe I start my pc a small window says the installer failed to exit a running instance of magic jack
I think magic jack relates to your sound driver/device. I would try removing and re-installing your sound driver. If you let me know your model of computer or sound card I may even be able to provide a download link for the drivers.
Posted on Mar 20, 2014
What Files Will Be Displayed in the Flash Memory in Addition to the Default Startup System Software Package and Configuration File?
After a device is powered on, it initializes the configuration by reading the configuration file from the flash memory. When you run the dir flash: command in the user view, the following information is displayed:
<HUAWEI> dir flash:
Directory of flash:/
Idx Attr Size(Byte) Date Time FileName
0 -rw- 812 Jan 01 2008 00:00:56 private-data.txt
1 -rw- 948 Jan 01 2008 07:16:55 vrpcfg.zip
2 -rw- 90,602 Jan 03 2008 03:58:15 v200r008sph001.pat
3 -rw- 6,418,980 Jan 19 2008 20:19:42 s2700-v100r005.cc
4 -rw- 12,240 Jan 03 2008 04:52:43 $_patchstate_reboot
14,632 KB total (8,228 KB free)
In the command output:
· The private-data.txt file saves service initialization data. Initialization data of some tasks is irrelevant to the configuration and is not recorded in the configuration file. The private-data.txt file records initialization data of these tasks, for example, the number of times the device restarts.
· The $_patchstate_reboot file records the patch status. This file is created after the device runs a patch and cannot be deleted. The file records the status of all patches, for example, the active state and running state.
· The v200r008sph001.pat is a patch file. The file name extension of patch files is .pat.
Sometimes, the flash memory saves a notilogindex.txt file. If a destination host is configured for Inform traps, the number recorded in this file is used as the initial serial number and filled in the Request ID field in Simple Network Management Protocol (SNMP) packets. The system starts a timer when the SNMP task starts and updates the file every 12 hours.
May 10, 2016 | Computers & Internet
Whe I start my pc a small window says the installer failed to exit a running instance of magic jack
Mar 20, 2014 | Computers & Internet
So I have an HP mini and when I boot up it says "Failed to initialize HAL!" After this I can't connect to wifi or use any USB ports or access system configuration
Best I could find is on this site, as you didn't specify what operating system you are trying to use: http://www.reviversoft.com/blog/2012/12/hal-initialization-failed/info. This usually only happens if you are using Linux or Windows 8.
Feb 10, 2014 | Computers & Internet
When I try to log on to Facebook it says Connection Failed, it doesn't matter whether I'm using Mozilla Firefox or Internet Explorer it says the same with both.
You should contact your PROVIDERS access. Ask the IP address of DNS server, and put in the web configuration (TP / IP) of your network connection ..
That's it.
Dec 30, 2010 | Facebook Apps
Every time i switch on i'm asked to insert blueyonder instalation disc!
Pls try:
  • Start, Run, type "msconfig" less the quotes;
  • in the System Configuration window, pls click on the Startup tab;
  • un-check any instance of Blueyonder and/or related files/dependencies;
  • click on Apply, OK, Reboot.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Computers & Internet
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
When i try to play the game it says its unable to initiate direct x and theres a problem with my system configuration for my game "crash days"
update your direct x and make sure your computer meets the games requirements
also make sure its able to run on your operating system
Jun 27, 2008 | Computers & Internet
Upgraded all hardware, installed all drivers, go to play a game that should work fine but system can't seem to handle it. screen starts to shutter. changed all settings to lowest so that it should provide...
Offhand, what I would suggest is to tweak your OS for maximum performance (not necessarily faster but more efficient and stable). Things you can try are:
1. right click on "My Computer", click on "Properties";
2. click on "Advanced" tab, click on "Performance Settings' button, in "Visual Effects" tab, tick "Adjust for best performance", Apply;
3. in "Advanced" tab, tick both instances of "Programs", Apply;
4. click "Virtual memory" "Change" button, tick "Custom size" type in 2048 or whatever it is that is twice of your memory on both Initial and Maximum, click on "Set" button, OK. OK;
5. Goto Start, Run, next small window type "msconfig" less the quotes, OK;
6. in the "System Configuration Utility" window, "Startup" tab, un-check everything (except perhaps your anti-virus), Apply, OK;
7. Reboot.
May 04, 2008 | Computers & Internet
Facebook Apps Logo
54 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Facebook App Expert? Answer questions, earn points and help others
