Question about Acoustic Research Audio Players & Recorders
Sub-woofer not working in AR5 tower speaker with powered sub
My Acoustic Research AR5 tower speakers have a side-firing bass speaker powered by an integrated power amp in the speaker. There is power getting to the speaker and the green light on back of the speaker indicating the sub amp is on is lit. But, the bass speaker isn't working. The other three speakers in the cabinet that do not require their own power source are playing fine. I checked inside the cabinet and the internal fuse is still good. Couldn't find a reset button anywhere. Did my integrate amp just go bad?
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
dunnbiker
  • 8546 Answers
SOURCE: replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
Posted on May 19, 2009
  • 3 Answers
SOURCE: Klipsch ksw subwoofer wont power on
The problem is Klipsch's problem, and they don't seem to want to face it. My 10" subwoofer blows the fuse before the power light can even come on. It's obvious that the fuse is not strong enough, but there is a delicate area between the fuse and the power supply. Too many amps on a fuse may keep it from blowing, but it may cook the power supply. Kipsch needs to fix this, tell us how to fix it, or replace it...at their expense. This should NOT be happening. Otherwise a great speaker....when it works.
Posted on Dec 14, 2009
Grubhead
  • 5126 Answers
SOURCE: Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Posted on Feb 09, 2010
  • 49 Answers
SOURCE: Mirage LF 150 Sub Woofer. sub not working
within the sub amplifier is an electronic amplifier, that is shorted and blown a fuse. This is all internal. If you can dismantle this module, I suggest do so and any electrical/electronic individual will identify the part needed. you could also check on a replacement module-complete.
Posted on Mar 04, 2010
Testimonial: "Spot-on Ron! I'll get another fuse. Many thanks, Chris"
Just got two AR 312 HO speakers from my brother. I have a Yamaha HTR 6250. The speakers have (2) sets of cable hook up. One I assume is for built in sub woofers? Do I hook one normal and one to the sub...
do not use those speakers with that amp, those are 4 ohm speakers, which could damage your 8 ohm yamaha amp. you will have to get a 4 ohm capable amp to run the highs, and another 4 ohm amp to run the subs.
car amplifiers are currently 4 ohm, or even 2/1 ohm stable, but few, if any modern receivers can run at anything lower than 8 ohms without a danger of overheating. you may have to get a vintage amp(s), like a 1970's marantz receiver, or a 1980's to early 1990's kenwood power amp, because 4 ohm home amps are pretty scarce nowadays.
whatever amp(s)( you get, verify that they are DEFINITELY 4 ohm stable.
Nov 06, 2010 | Acoustic Research 312 HO Speaker
Will the woofer work without the other two speakers?
There is no point.
The woofer(sub woofer) just delivers the bass. You usually put the sub woofer out of the way under your desk.
Without the other speakers you would just get the thumping bass and no treble
Aug 30, 2010 | Yamaha YST-MS201 Computer Speakers
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
May 20, 2010 | Acoustic Research AR1 Speaker
I can't get bass thru the spkrs
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Feb 12, 2009 | Sony Audio Players & Recorders
JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
Aug 12, 2008 | JVC TH-M606 System
"cracking" noise
Your subwoofer is not capable of playing as loud as you want it to. That sound is the woofer reaching its limit. If you have any bass tone setting on your receiver set them to flat. If there are any other bass settings i.e contour, loudness boost etc turn them off. You can also try putting the woofer into a corner. This will increase the output. Closer to you would also be louder. Otherwise you need a sub with more output. Don't let the power rating fool you when you get a new one.
Aug 26, 2007 | Acoustic Research ARS108 Speaker
Amp and sub bass playing through all speakers
You need to go into the setup menu and find out if the radio has a sub low-pass filter that redirects the bass to the pre-out for the subs, and away from the main speakers. Fiddle in the audio menu.
Apr 15, 2007 | Xtreme Sound WMS336 CD Player
98 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
