Question about GPX Televison & Video
I have a GPX TD910B Tv with DVD player,the internal battery is not charging and it'd not the charger,where can I go to have this unit repaired?
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
SOURCE: remote codes for Ilo tv or gpx dvd player
i have universal remote and tv gpx soi need thecodes
Posted on Jun 25, 2008
  • 303 Answers
SOURCE: lost battery charger need new one
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger GPX PDL805
Posted on Mar 04, 2009
  • 303 Answers
SOURCE: Battery Charger for Trutech Portabel DVD player
click on hyperlink:
buy replacement ac power power battery charger adapter for Trutech PVS12701
Posted on Jun 03, 2009
SOURCE: Region hack needed for GPX PD907B DVD Player
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
Posted on Dec 06, 2009
I have a GPX PDL705. I am getting a flashing battery symbol in the top left corner when I try to play dvd. This happens with cord plugged in and without. What does this mean?
if it plays ok with the cord plugged in then you might have a shorted cell in the battery.. that prevents the battery voltage from ever getting to its design value .. the charger shows this like the battery never gets charged ... removing or replacing the battery should eliminate the blinking symbol...
Jun 24, 2010 | GPX PDL805 Portable DVD Player
Problem charging my gpx ml759b
The GPX ML759B has a Lion-Polymer rechargeable battery which does wear out pretty quickly especially when playing MP4 Videos. If your unit is 18months, you have done well!
If you have tried charging charging your player in a couple manners as stated, and you are happy that the charging system is working, then I strongly suspect that you will need to replace the internal LiOn-Polymer battery (whcih usually have a max life of 500 charges).
If you cannot replace the internal battery yourself, you may find that it may not be an economical option for a relatively cheap MP4 player.
Dec 19, 2009 | GPX Audio Players & Recorders
How do you charge it
to charge the GPX ML6488 MP3 Player, you have to find the AC Charger design for GPX then locate the power outlet for GPX then plug the exact or match connector from your charger then plug the AC Charger to the power outlet then wait the MP3 's battery become full.
thanks
Sep 14, 2009 | GPX ML648B MP3 Player
Wont charge
Isolate the problem. Try using another charger or bring the device to an authorized repair shop so that you could try another battery.
Most repair shops have their test batteries available.
Doing these would let you know which one is causing the problem. Is it the battery or the charger. If none of them is causing the problem, I'm sure that there's a loose wire inside that needs to be soldered.
Aug 29, 2009 | GPX ML648B MP3 Player
GPX DVD Player
Most items, first time your have to charge it for continious 8 to 11 hours. On that time it fully charge the battery and internal battery. I would say charge it for 11 hours.(It wont over chage on anything.)
But, if you already charged it for some time, discharge it fully. (Leave it playing till it wont even turn on when you puch the power button) Then charge it backfor11 hours.
Cheers!!
Mar 13, 2009 | GPX Audio Players & Recorders
GPX DVD player flashing power light
Ihave a GPX portable dvd player that has a broken charging jack on the unit itself. The model is a GPX 808.
Mar 11, 2009 | GPX D1816 DVD Player
Dvd player wont spin disks
Sounds like a bad motor or motor controller inside the unit. Does it have fresh batteries?
nssms
Sep 15, 2008 | GPX PDL805 Portable DVD Player
Ac adaptor
I just called Gpx for a Car charger and they had in stock (as of 6-17-08) it was $14.99.... the wall carger was $9.99. Hope that helps. GPX phone # 314-621-2881.
Jun 08, 2008 | GPX PDL705
Televison & Video Logo
49 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
