Question about Garden
I have a Huskie LT 4200 Mower and sometimes it will start and sometimes it won't. When key is turned it has a click under the seat. After turning key back and forth several times it will start. Help!
    Top Expert:
  • Garden Master
  • 51,587 Answers
Sounds like the seat safety switch is failing replace it and see what it does then
Posted on Apr 26, 2015
  • 41 Answers
SOURCE: won;t restart..
Check battery,if it's good, check charging system.
Posted on May 08, 2009
  • 148 Answers
SOURCE: craftsman lz3000 lawnmower wont start after turning it off
Do you have a multimeter? If yes then check for continuity with the meter. If not then remove the wires from the switch and short them together (get a piece of wire and insert each end into the spade connectors on each wire.
Posted on May 26, 2009
SOURCE: Starter often just clicks wont turn over every time
I had a similiar problem. Finally it would not start at all. I replaced the solenoid switch and problem solved.
Posted on Jun 01, 2009
SOURCE: i have a countax a20-50.when starting engine with
I have a Countax A2050 and the deck is not lifting when I press the button on the dash, What is my problem?
Posted on Apr 01, 2011
  • 6468 Answers
SOURCE: Riding mower engine won't turn over, just clicks
try and jump start it with your car
Posted on Apr 03, 2012
What will not let my mower start?
try the brake switch unhook and jump if does replace swtch that how you check the safty check the one under seat leave un jump then try jumped check al like this you will find bad switch 3 to 4 switchs all lawn mowers
Aug 26, 2014 | Garden
Ferris mower
Yes bad seat switch.
Nov 30, 2017 | Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
2001 Cadillac SLS won't start
Hi, The clicking you hear is the anti theft system has been triggered, beneath the steering column pull down the fuse cover and locate the (ECU) fuse Labeled so on cover and owners manual. Remove (ECU) fuse turn ignition to on only, do not start, wait 3 minutes turn off ignition remove key, reinstall (ECU) fuse. Try starting Vehicle!
Feb 21, 2018 | 2001 Cadillac DeVille
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
Try starting my 19.5 hp craftsmanriding mower and no click and cross over the solnoid and it turns over but no start
If it is equipped with a seat safety switch it won't start unless someone is on the seat or the switch is bypassed (which you shouldn't do for safety concerns). You could also have a bad ignition switch which is not uncommon.
May 18, 2012 | Craftsman Garden
I have an older electric start craftsman lawn mower. It's @15 years old and runs well. I just don't know where to plug it in on the mower for the electric start. It was my Dad's but he's gone and I have no...
"Electric Start" means that it is started by an electric motor (the starter) which is powered by a BATTERY (the electric) much the same as a car. One does not PLUG it in. If it does not turn over when you turn the key, repost your question and include the Sears model number >>917.xxxxxx<< the x's being numbers 0 thru 9 off the tag on the back end of the mower near or under the seat and I will see if I can steer you to an operators manual for it
Aug 31, 2009 | Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
