Question about Kubota Garden
I just bought an old used Kubota ZG 20 48 inch deck... Need to change the blades... What size are the blade bolts and is it left or right hand thread
    Top Expert:
  • Kubota Master
  • 42,930 Answers
What do you think we are we can not test the size like you can and should .rightie tightie lefty loosey
Posted on Apr 26, 2015
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: Can't get bolts loose on mower blades
The bolts that hold the blade need to be turned clockwise.
The bolts holding on the deck need to be turned counter clockwise
Posted on Jul 29, 2009
nova2nv
  • 197 Answers
SOURCE: Ihave an old john deere lawn mower 21 inch
Always unscrew the bolt in the same direction of blade travel.If the blade travels clockwise,loosen bolt by going clockwise.
Posted on Mar 24, 2010
jyackle5
  • 8197 Answers
SOURCE: Are the bolts on a John Deere F715 blade right or
The bolts that hold the blad on are left hand thread.
Good luck and please rate 4 thumbs up for the free answer.
Posted on Jul 04, 2010
miket756
  • 2702 Answers
SOURCE: 42 inch jd la115, hit stump in yard, changed blade
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Posted on Aug 15, 2010
What would cause my walker zero turn mower right blade to fall off of become loose after tightening the nut about every 5 minutes while mowing?
check to see if that side is supposed to have a left hand nut on the correct spindle
are you using the dish shaped washer under the nut
are you using a spring washer or nyloc nut
Mar 28, 2016 | Garden
Does each blade turn counter clockwise to be removed?
All that I have seen are right hand threads. What make and model of mower do you have and how many blades?
Jun 03, 2015 | Garden
Are the Cutting blades bolts for a John Deere LT 160 right handed thread or left handed thread?
It is typical to use right handed thread so you would turn them clockwise to install, and counterclockwise to remove. The blade rotates towards the cutting edge which is typically counterclockwise, so to remove the bolt, you unscrew it, with the handle of your wrench pulling towards the back of the blade.. These bolts can be really tight. Pull the spark plug lead or remove the ignition key so you don't get an accidental start. Wear gloves, there are sharp bits.
Mar 17, 2015 | Cars & Trucks
T1770 cutting blade removal
Kubota blades, are they counter thread
Feb 14, 2013 | Kubota Garden
Does the blades have left hand threads or right hand threads when relacing the blades
The blade bolts have a normal right-handed thread orientation. But remember, when you are installing a blade bolt, the bolt is facing UP from the ground, not DOWN to the ground; hence the confusion.
Jul 19, 2011 | Craftsman Garden
Motion drive belt shredded. what direction do I turn the pulley bolt on the bottom of the crankshaft under the engine?
It is normally threaded, which is to say it has right hand threads. So you will need to turn left to loosen. You can take a block of wood to brace the blade or use vice grip pliers to block the blade. The blade needs to be immobilized to loosen the bolt.
If this is really helpful for you, please rate four thumbs up.
Jul 18, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
On a 10 inch power compound miter saw, I need to replace the blade. Does the blade bolt have left handed threads? Thanks
Place a finger nail in the thread near the end ot the shaft. If when rotated CW it comes off the shaft it is a left hand thread. My 10" Craftsman radial saw has a left hand thread on the blade shaft.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 30, 2010 | Craftsman Garden
Ihave an old john deere lawn mower 21 inch #GX1458. Is the blade screw left or right hand thread
Mar 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Changing blades.To loosen the blades nut, which way does it turn?
hi. you dont say what make or model but I offer the following. if it's just a single bolt or nut holding the blade it will rely on a bellville type washer (dished ) or will be pegged either side of the nut or bolt, if the later try to drive the pegs down level with the mounting boss, now get a couple of friends to lift the whole deck so you can secure the nut or bolt in a vice (vise) and using both hands turn the blade itself the opposite way that you would turn the nut, this has never failed for me, if the blades counter rotate, one will be left hand thread the other right hand. bear in mind that a rotary blade spins at around 150-200 mph, every time you hit an obstruction (and you will) the blade will tighten particularly if secured with a belleville type washer. best of luck
Nov 28, 2009 | Garden
Jul 29, 2009 | Garden
Garden Logo
112 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
