Question about GPS
Is the eagl ultra classic a gps - GPS
Is this a g.p.s. also
Sorry Kurt
This unit is a fishfinder only.
If you require the owners manual, check the link below.
-Steve
http://www.eaglenav.ca/upload/Eagle/Documents/Manuals/uclassic.pdf
Apr 26, 2015 | Eagle Boating
2006 FLHTCUI ultra classic starter clutch repair
Hi Anonymous, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 26, 2012 | 2006 Harley Davidson FLHTCUSE Screamin...
Ignition switch grounded on 2006 harley ultra
Hi Anonymous, try replacing it with a new one. Good luck and have nice day.
Jul 23, 2012 | 2006 Harley Davidson FLHTCUSE Screamin...
Need ideas to successfully mount FLHTCUSE4 "stock" air cleaner cover to Screamin' Eagle Stage 1 filter.
If you have the screaming eagle cover to compare it to it is easier but if not you can cut back the "sides", sometimes leaving the front the original size.
Sep 13, 2011 | 2009 Harley Davidson FLHTCUSE4 CVO Ultra...
I just pulled my 2006 screaming eagle ultra classic out of winter storage and it won't start. The battery had a full charge and it makes a long clicking sound when I try to start it. It's the...
Harleys pull a lot of amps starting,, Just because the battery says 12v doesn't mean the charge is handling the draw when trying to start them ,, get the battery LOAD checked,, remember also,, Harley's are known for drawing Juice when starting , thats why any dealer or shop will tell you that if you start one be sure and drive it a while,, start and stop trips eat up the battery since the alt won't keep up with the charging. when I leave mine for any time, I use one of the trickle charge units just to keep it at full
May 13, 2011 | 2006 Harley Davidson FLHTCUSE Screamin...
2003 Harley Davidson FLHTCUI Electra Glide Ultra Classic idles about 1200+ and i do not know how to reduce the idle-just bought yesterday and is first one with fuel injection. How do i lower it? thanks...
You cannot, unless you have the Screamin Eagle Race Tuner (SERT) or you take it to the dealer (at about $80/hr.) Sorry I don't have better news, hope this helps.
JP
Nov 23, 2009 | 2003 Harley Davidson FLHTCUI Electra Glide...
Need Manual
You can download the manual from the following link:
http://www.eaglesonar.com/Downloads/Manuals/Files/uclassic.pdf
Apr 30, 2009 | GPS
Ultra Classic has miss when cold and a vibration
Hi Lcampeau12, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Mar 16, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
GPS Logo
64 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
