Question about Amana Refrigerators
Model afi2538aes ice and water dispenser not working. Works intermittently press actuator and sometimes ice and water will come out sometimes it won't. There is a button on the panel to turn light on
That works and can adjust temp of fridge. Any ideas
  • Amana Master
  • 5,323 Answers
ICE MAKER not making ice
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
God is the reason I give you free advice so God is good!
model afi2538aes ice and water dispenser not worki - 25667347-izj50bzy441rirqhwblyybfs-3-0.jpg
25667347-izj50bzy441rirqhwblyybfs-3-2.jpg model afi2538aes ice and water dispenser not worki - 25667347-izj50bzy441rirqhwblyybfs-3-5.jpgt/uploads/images/25667347-izj50bzy441rirqhwblyybfs-3-5.jpg" alt="25667347model afi2538aes ice and water dispenser not worki - 25667347-izj50bzy441rirqhwblyybfs-3-9.jpg"h_mi" />
model afi2538aes ice and water dispenser not worki - 25667347-izj50bzy441rirqhwblyybfs-3-20.jpgmages/25667347-izj50bzy441rirqhwblyybfs-3-14.jpg" alt="25667347-izj50bzy441rirqhwblyybfs-3-14.jpg" class="h_mi" />
Posted on May 12, 2015
  • 32 Answers
SOURCE: Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Posted on Jul 04, 2007
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
woodchuck789
  • 4070 Answers
SOURCE: ge gss fridge,ice dispenser problem.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. The crush position is without the solenoid energized. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Your solenoid is part 45 and the linkage to the crusher is 46. The crusher is 41 on this diagram and parts list. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239793#d1239793
Posted on Feb 28, 2010
Testimonial: "Solenoid was stuck,thanks"
Ice not dispensing from the freezer door. Water dispenser works fine.
It sound like the switch is not being hit from the actuator. If it is a whirlpool or some Kenmore models then there is a switch bracket that is notorious for breaking the switch mounts. Pop the front frame carefully off usually from the bottom with a putty knife and this should reveal a switch bracket. Other brands will come apart differently.
Apr 21, 2015 | Refrigerators
Subzero 680 water dispenser working inconsistently.
This sounds like the inlet water solenoid valve is faulty. This valve is connected to the water supply line coming from your house.
Jan 26, 2015 | Refrigerators
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Water Dispenser Works Intermittently
either the micro swith is bad mounted on actuator arm.if it is a ge check the barrel connection located under upper door hinge cover round barrel connnectors sometimes do not make good contact.spread male eds with small ponted awl or anything
Apr 10, 2013 | Refrigerators
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Model JCD2389GEW - ice/water dispenser does not work. Until recently, it did not do anything on any of the settings (water, cube and crushed ice) now it crushes ice on all three settings but the door does...
We have a Jenn Air side by side, model JCD2389GEW. The ice dispensers work, the water does not. This started after I replaced the filter. I've checked and nothing is locked out. When you press the actuator pad to dispense water, you can hear a noise similar to a small pump which I assume is a solenoid attempting to open. Any ideas?
Oct 02, 2009 | Jenn-Air Refrigerators
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
115 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
