Question about Garden
The mower engagement lever was super hard to engage and when it did the lever broke free and now I can't engage the blades. I can see a spring , how do I fix whatever broke?
  • 1,169 Answers
Most likely you just broke your PTO engagement cable and it needs replacing.
Posted on Apr 27, 2015
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
When I engage the lever for the blades to start cutting, the blades don't engage
Check for bad or loose belt also see if you are missing a shear pin in one of your drive pulleys. See if your lever to engage the blades is actually putting driving pressure on the belt. Could be a spring is missing as well.
Apr 12, 2015 | Garden
Why will blades will not disengage?
check your return spring on the deck. it goes from hole in bracket welded to deck to hole in moving lever that one of the deck pulleys is attached to. if spring is missing or broke, it will not dissengage or may dissengage slowly. If spring is there, the moving lever may have debris under it or may be bent. If spring is there, remove deck and try pushing the pully with the spring to see if it breaks free.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower blade not engaging
Check your belt. May broke, off, slipping.
Apr 05, 2014 | Snapper Garden
My YTS 3000 will run but the blades won't engage. Engagement lever is really hard to push up but when I try to engage blades, nothing. Could it be the cable?
Find where the cable is connected to the deck. Have someone move the lever and watch the end. Does it look rusted or bent?
Unclip the cable at the deck. Then try the cable. If it moves freely there is something rusted, bent or broke on the engage pulley mechanism on the top of the deck.
Nov 02, 2013 | Craftsman YT 3000 42" Kohler 22 hp Gas...
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
Two springs broke underneath the riding lawn mower 3800 and we don't know where to replace them at, they engage the gears.
First make sure you can still engage the blades.Many mowers use a cable attached to a spring to engage the blades.If that is one of the springs,you need a new cable.For the other I will need more information,like what kind of mower is it?How many blades?Another thing to look for is worn or torn holes that the springs attach to.
Jun 29, 2011 | Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
I have an 89 snapper riding mower . all of a
Check the springs, and nuts, and see if the pulley moves and doesn't stick when engaging/disengaging
Jul 20, 2009 | Garden
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
