Question about Sewing Machines
I can't get it to turn on
I have had this problem in the past but it usually takes it a while for it to turn on.
  • Marla
    Marla Apr 26, 2015
    It has been sitting all winter, it has hardly been used since I bought it brand new. Once again it is the bernina patchwork edition. Thanks
  • Marla
    Marla Apr 27, 2015
    I tried different outlets, and still nothing.
    Top Expert:
  • Sewing Machines Master
  • 51,518 Answers
Get a can of contact cleaner and spray the switch then work it on and off with cord unplugged then try it . many times it will be a little corrosion and this will clean it .
Posted on Apr 27, 2015
The clutch will not release in order to fill a bobbin. Past owners have been directed to remove the clutch knob. How do you remove the clutch knob?
Hi Victor, In general all sewing machines have the same basic design. So, if you take hold of the big 'wheel' on the right of the machine with your left hand and take hold of the knob in the centre of the wheel with your right hand you should be able to turn the knob anticlockwise. That's the cluch disengaged. You should now be able to fill a bobbin. Don't forget to engage the clutch before sewing (just reverse the process).
Jul 16, 2015 | Brother Sewing Machines
The upper looper is jammed and will only move up and down not left or right
Turn everything off.. at the power supply... (safety first)... you will need to rethread your machine...and try again.... But in the past I have had to take my serger/ overlocker into the technician... usually meant the upper looper arm was out of whack 'due to tension too high'... I do a lot of stretch knit sewing.. jarmies and baby onesies etc... not a bigger... quick to replace... I did notice that it was worse when my fabric was too 'light/thin'... and would often jam then...
Mar 21, 2014 | Brother 1034D Serger Sewing Machine
Thread got caught while winding endless bobbin motor got hot. Machine said to save design, turn off machine and let cool. The machine will power up but won't sew. You can make stitches by turning the hand...
No familiar with this model...But, It could be a fuse has burnt?? Especially if the motor was working double time . The fuses are usually 2.5 to 3 Amp. Make sure to leave it off for several hours then try to turn it back on first. If that doesn't help, take it in and explain the issue. Fuses are cheap and usually not to timely to change
Machine Tech
Oct 22, 2013 | Singer Quantum XL-5000 Computerized Sewing...
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
My tension on my machine is wrong. when i try my design the bobbin thread shows on the top and i have tried all the tensions on the machine. i just got it back from a dealer that fixes them. but i am still...
Are you using machine embroidery thread top and bottom? Madeira or something similar with a silky sheen. Always, same thread brand and weight top and bottom although you may want different colours for some tasks.
Also you will need stitch and tear or some other suitable stabiliser under the fabric to give it body and support during the stitching.
Have you embroidered successfully on this machine in the past and this problem has now occured?
If so, I would take it back to the dealer and ask him to test sew a design with it and see if he can get a good result out of it.
If you are new to machine embroidery then perhaps visit http://sewing.about.com/od/machineembroiderytips/Machine_Embroidery_Tips_Information.htm for lots of help and advice on machine embroidery.
Also I'd suggest that you revisit how you wind the bobbin - check your manual or there is more on this on sewingabout.com as it is essential to get a good smooth wound bobbin with no jerks or unevenness - you don't want the thread stretched unevenly onto the bobbin as it will relax unevenly when stitched out.
Then revisit bobbin threading into tension device, bobbin thread showing on top of fabric is usually indicative that there is insufficient tension on the bobbin thread, check that it is fully into tension and bobbin is in the right way, you always want the thread to come of the bobbin in a "V" shape, and bobbin should turn anticlockwise as you pull thread from it usually (but please check machine manual for specific threading for this machine, there is always the one exception).
Finally, does your machine have tension adjusments on the bobbin case? some have a little dial that will allow you to make small adjusments, although usually not necesary, adjusting the top tension is usually all that is needed.
I hope this is of assistance to you, obviously if you have tried all the above already, then I'd go back to the dealer and see if he can get a better result for you.
Jun 21, 2011 | Brother PE-150V Computerized Sewing...
When I turn on my hp it shuts right back off. Any idea what may be the problem? Thanks
Hi the usual cause of it switching strait off is due to the processor over heating, now it may be a case of just getting the heat sink paste replaced or it could be worse and you process could all ready be burned out if this is the case then the chances are a new computer would do you better.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 31, 2010 | Sewing Machines
Viking Huskylock 910 Upper Looper problem...
You will find that it was most likely the top looper has moved to the left too far, undo the looper clamp and press the looper to the right by about 3mm. Then turn the machine over to see if it still hits anything, when the top looper comes up past the bottom looper there should be about 0.5mm clearance between the two. Try this first please.
Also the arm shaft may have moved. Trace the shaft back to where there is a clamp type crank with usually a hexagon head clamp screw. Loosen this and set the top looper so as the eye of it is just past the needle when it is all the way up and to the left.
You are correct in not using the machine under power, turn by hand when you think it is correct and make sure there is nothing hitting.
Jul 06, 2009 | Husqvarna Huskylock Computerized 910
Sewing machine motor may have seized up
The oil and grease in your machine has turned into a very sticky, syrupy mess and needs to be chemically removed . My guess is that even if you were able to get the machine to turn freely it wouldn't zigzag . I really recommend that you take the machine to be professionally serviced again and do not let it sit idle.
Once it is serviced,test it before you bring it home again. These things are kind of tricky sometimes.
sewman7
Mar 31, 2009 | Sewing Machines
Sewing with walking foot
Take the needle out and run the machine for a while with the walking foot fitted. Refit the needle and try again but only turn the machine over by hand to see if the problem has cleared. If no luck it sounds like the walking foot timing needs adjusting.
Apr 05, 2008 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
