Question about RCA P52939 52" Rear Projection Television
Rca big screen want come on
When i turn my tv on i just hear a popping noise ,what do i need to do
  • hawkinsfam Mar 08, 2008
    my rca projection tv doesnt play audio thru the coaxle, only thru the inputs. therefore if i have cable without a cable box i cant hear sound
  • 1,694 Answers
1) Replace IHVT (aka flyback transformer ) Part # 250694
2) Replace HV BLock part # 250671
3) Check for arcing CRT ( red,green or blue )
Please rate this solution.......
Posted on Nov 14, 2007
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it : That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here: .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Need model # more than likely you have no high voltage going to crt. It could be horizontal output and starter caps and much more. Is there any lights that stay on when pressing power?
Sep 10, 2007 | Televison & Video
Popping noise
The anode cap on the back of the tv tube is leaking the high voltage be careful as going into the back of a tv it store very high voltage and could be fatal.the solution to problem get a tube of clear or red silicone discharge the high from the tube,you do this by getting a alligator clip with wire attach clip to a ground wire on the back of the tube attached the other end of the wire to screw driver gently push it under the Anode cap you will hear a popping sound with i little sparks. remove the cap from off the tube get some alcohol wipe the dirt away apply the silicone around the anode and the anode cap place in on back and leave it to dry and cure for about 7 hrs close up back and turn on your tv and all the popping sound is gone.good luck.but if it is the wire for the anode cap that comes from the flyback is the one leaking change the flyback.again good me on or email me at
Apr 24, 2007 | RCA 27V520T 27" TV
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
My tv will not turn on
I took my TV apart and solved the problem on my own. For those of you that have basic electrical skills and can solder it is an easy fix that only takes about one hour. I removed the rear cover and pulled the left side board which houses the flyback transformer, easily identifiable by the big orande wire coming off of the top. If one looks carfully the soulder connection will probably be broken or loose which can be caused by movement or heat. I resoldered all of the connections for the transformer about 12 and the grounding wire to the left, a single black wire that plugs into the board. Once this was done I put ti all back together again and no problems since!
Oct 29, 2006 | RCA HD52W58 52" TV
RCA P52939 52" Rear Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
