How to get rid of this doccument jam scanner on display and there is no paper in it at all or dust nothing at all
  • Brett Duxbury
    Brett Duxbury Apr 26, 2015
    Hi Dave Soper, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? model number and make of scanner
  • 5,631 Answers
Check Control Panel and CANCEL any print operation. If no result, disconnect printer, connect it again. Noting?
Remove first color then BW ink heads, try. Noting?
Disconnect USB and power. Connect again.
Same stuff?
Uninstal Printer and try to reinstall it again.
Nothing?
Well if after ll this your printer is still hanged up, you should take it to service
Posted on Apr 27, 2015
Brother DCP 330 Paper squizes and jam
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Dec 22, 2010 | Brother DCP-330C All-In-One InkJet Printer
Paper jam - sounds like gear problem
Dec 17, 2010 | Brother MFC-845CW multi-function...
I can't get my brother printer to print photos Keeps saying paper jam even though no paper jam
Sep 23, 2010 | Brother MFC-685cw InkJet Printer
Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Apr 27, 2010 | Samsung CLX-6210FX Laser Printer
How do you get rid of error light with no obvious paper jam on HL2140
the eror is probably caused by dust or paper slivers somewhere or a open door or the paper trat not being in right. Open everythign up look for dust and stuff then makre sure it is all closed and the tray in in right. It should then reset and the error goes out.
Usually this is from dust on sensors or a tiny sliver or paper jammed somewhere. Can be quite annoying to find and get rid of.
Mar 23, 2010 | Brother HL 2140 Laser Printer
Richo is200e scanner ADF thinks there is paper in the ADF and asks to clear the originals before trying to scan. We have checked the ADF for paper jam and tried cleaning the unit but it will not clear the...
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Mar 22, 2010 | Ricoh IS200E Flatbed Scanner
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
Jamming of paper using the Automatic Document Feeder
You may have a really tiny paper jam. You need to open up unit to get access to feeder properly. Use a torch, jams can be so small you can miss them. cheers lilacgerry
Jan 28, 2008 | Brother MFC 6800 All-In-One Laser Printer
jasbo
jasbo
