Question about Electric Razor Pocket Rocket Ride-on Motorcycle
What does the coil gap at on a 49 cc - Electric Razor Pocket Rocket Ride-on Motorcycle
Weak fire on pocket bike
Hi, I do a lot with these bikes, I think if you are getting a weak spark there is a couple things to check. First, do you understand how it builds the power to create the spark? The magnet in the flywheel has to be very close to the magnito or coil, if the gap is too much it will cause a weak spark, if the magnet is weak, weak spark, if the coil is shorting internally, weak spark. If the plug wire is damaged, weak spark. I hope this helps you.
Jan 25, 2015 | Quad 47 cc / 49 cc Pocket Mini Bike...
Zhejiang atv
Contact local atv dealer for assistance
Aug 10, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
No fire from spark plug
either spark plug is bad or coil is bad also check clearance between fly wheel and coil
Oct 08, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a chinese scooter starts and idles for a few seconds and then dies do you know what the problem is?
check the hoses that put gas on the carburator, and also the pump. Check the spark plug, better take it off and clean it and check the gap.
May 19, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
My midi quadard won't start.
are you getting a spark? if not change coil
May 02, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a 47cc pocket rocket and there is no spark at all.
first, if all connections are good, try replacing the spark plug, if still no good, check if coil gap to rotor is .020". if the is good, you will need to replace the ignition coil.
Oct 17, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
How to put the string back into the coil
A lot of people don't even bother trying to fix a recoil because they don't cost much to replace. maybe $10. but if you try make sure you don't let that coil unwrap or you will have a lot worse problems then just the string :p
If you can successfully get the cover off without allowing the coil to come loose then simply just wrap the string back up.
Jun 28, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Electric Razor Pocket Rocket Ride-on Motorcycle Logo
44 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
