Question about Garden
Lawn tractor will not start
Checked oil and noticed oil cap was not screwed on tight. Turned key, engine does not crank (have gas). Checked for loose spark plug wires and noticed oil on top of engine and side of oil cap. Guessing this was from hot oil spurting out of loose cap. What steps to look at to fix not starting. This is a 2014 model and was running fine the last mowing (yesterday).
  • Garden Master
  • 2,392 Answers
Is the battery fully charged? Are the battery cable connectors tight and no corrosion on both end of cables..
Posted on May 03, 2015
After 45 minutes of run time drops to half power
it is droping to half power to stop the motor from over heating check the water level and oil top them up.
Jun 27, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Car starts and drive 1 hr stop and won't start sounds like no gas but has gas in it
Does it stop itself or that were you who turned engine off?
Apr 24, 2015 | Cars & Trucks
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Lawn tractor run fine with full tank of gas but runs ruff, and acts like its running out of gas when fuel level drops below 3/4 tank. The problem has gotten progressively worse over the last few...
hi there FIXor Destroy
have you checked and tried running tractor with the fuel tank cap loose or off in case its not venting
and stopping fuel flow , have you checked for debris in the carb and main jets / emulsion tubes and air bleeds ? if it has a fuel pump is it working properly ?
are you sure the valves dont have tight clearances ?
is the tank getting alot of vibration , may be getting vapour loc from fuel agitation in the tank, or some kind of heat transfer from the engine to the fuel
take a look
cheers pauly46
Jul 02, 2011 | Craftsman Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Troybuilt/bronco wont start
IF YOU HAVE A NEW BATT IT COULD NEED THE VALVE LASH RE SET
Sep 19, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Engine won't Start
If you have 3 qts. of oil in your mower, drain it immediately. It only holds 3 PINTS or 48 ozs or 1 1/2 qts. Next, remove your spark plug and put the end away from the hole (to prevent possible arching and fire) and crank the engine over. Probably, a lot of oil/gas will blow out, clearing your cylinder. Clean the plug and try to restart. If it still reaches a point where the engine will not turn past while trying to crank, the valves need to be readjusted. Also check by smelling the dipstick that there is no gas mixed in the oil. That would mean your carb needle and seat are leaking.
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
6yr old Craftsman Lawn Tractor - Koehler 18 HP Auto. Sputter&Dies
Try running it again and when it starts to die remove the gas cap and see if it starts to run better. It's possible that the gas tank isn't venting correctly. If that doesn't work post back and we'll try to come up with some other solutions.
Apr 22, 2009 | Craftsman Garden
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
