Question about Vehicle Parts & Accessories
My clutch engine won't start - Vehicle Parts & Accessories
  • 3,462 Answers
Hopefully it is running mpw? If it is not please add more detail and resubmit the query
Posted on Jun 15, 2015
How do I trouble shoot an engine that won't start?
Hi, Frank and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping. Good luck and have nice a day.
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
What to do When Your Motorcycle Won Start
Troubleshooting No Start Honda Motorcycle
Motorcycle Won Turn On Solved
Mar 06, 2016 | Motorcycles
Trouble shoot 2500masda truck that won t start after I replace clutch and slave cylinder
Did you reconnect the wires and re-position the clutch safety switch at the clutch pedal assembly? If this switch is not positioned or connected correctly it will not allow the truck to start.
Feb 25, 2015 | 1999 Mazda Pickup
I was driving my 99 neon and heard a pop. The clutch peddal went to the floor and i cant get the car to go into gear
the hydraulic slave cylinder may have let go and will need replacing. its also possible that the clutch pressure plate broke or the clutch plate. you don`t say how many miles you have on the clutch. you also don`t say if it won`t go into gear with the engine running, which indicates clutch, or with the engine off.
Jul 30, 2014 | 1999 Dodge Neon
Engine revs but no acceleration
Clutch plate and pressure plate seem to be too weak to pull the car. Or one of the CV joints is detached from the gear box. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
May 22, 2013 | Honda Civic Cars & Trucks
Why won't it start?
There should be a clutch safety switch that prevents you from cranking the engine with the clutch engaged.
Have you checked the switch for power ?
Apr 26, 2013 | 2007 Scion tC Coupe
My '95 Tercel won't start
clutches don't pump up unless there is air in the system. Check the slave cylinder for oil leaking. There may be a switch that has to be in the correct position to allow the system to start and unless you can activate it when the clutch is disengaged it will ne difficult to start. I would also check the battery with a load test as bad cells will not give a high enough crank speed to fire the engine
Apr 07, 2013 | 1995 Toyota Tercel
My clutch won't engage 1997 Honda civic
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Apr 06, 2013 | 1997 Honda Civic
Clutch won't release
Start with inspecting the clutch handle for any obstructions or rust.
Lubricate the clutch cable at the handle.
Follow the cable down and look for and pinching or damage.If you can follow the end of the cable to the actuall clutch mecaniism, inspect the area for clearance.
If you can disconnect the cable from the clutch mecanisim and test the clutch handle to see if the cable moves freely.
Manually try to engange an clucth with the engine off.
If it won't move, time to diassemble the clutch.
Apr 07, 2012 | 1996 Suzuki VS 1400 Intruder
Won't start. String pull will not go more than a few inches. Engine seized?
Try the clutch. I just fixed this problem.One of the clutch springs ate it's way though the red housing where the spring for the pull start is at. When the housing came apart the engine seized and I couldn't move the pull start. For the schematic on the engine here is the web address http://www.searspartsdirect.com. Hope this helps.
Aug 20, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
