Question about Cub Cadet Garden
My Cub Cadet will start but when break is released engine dies
    Problem Solver:
  • 15 Answers
Check your seat switch. What model Cub Cadet is it?
Posted on May 02, 2015
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
Cub cadet lt 1042
Some of those cadets (like those with the Command 20) have a compression release mechanism on the cam which is intended to make that engine crank easier but disengages once the engine fires up. It's a plastic part and is prone to break, resulting in a lot of strain on the starter motor. Interesting design, bad materials. Sometimes the engine will start anyway but this is not a good idea to operate this way. Pull the valve cover. Look at the motion of the exhaust valve when you turn the engine by hand. It will look similar to the motion of the intake valve if this part is broken. If it's working correctly, you should see the exhaust valve open slightly just after the intake valve closes. I'll attach a video to show what it looks like. Replacing the bad cam is a bit of work but not terrible.
Oct 04, 2013 | Cub Cadet Garden
Cub cadet runs fine until I start the PTO, then it stutters and dies. If I shut off the PTO blade, it will pick back up and run again
I had a similar problem with my cub Cadet. It turned out that the Ignition Module on the engine was cracked. Motor started OK - but died as soon as a load (such as engaging the mower) was put on it.
These are not terribly hard to check, and/or change, yourself. Easy to get to once the motor shroud is removed.
My 25 HP Kohler engine has 2 modules. EXPENSIVE from the dealer - found MUCH better prices online.
Aug 30, 2013 | Cub Cadet Garden
Cub cadet 3654
sounds like the seat safty switch is bad.its located under the seat.replace and try again.
Aug 20, 2013 | Garden
Cub cadet 2166 dies when I engage PTO or let brake peddal all the way up
replace that safety switch there is two switches built into one
Jun 11, 2012 | Cub Cadet Garden
1320 cub engine starts to die when going in revers
is your blades spinning when you try to go into reverse?
May 29, 2012 | Cub Cadet Garden
I have a zForce with a 23 HP Kohler and 50" deck When I start the mower all is fine until I release the parking break and the motor dies. Anyone got an answer
Make sure your foot is on the clutch pedal. If that is not the problem check the safety switch on the parking brake. Good Luck...
Mar 24, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
119 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
