Question about Moen Plumbing
Water flow is terrible, removed green check valve, now its great. Is there a problem not using the check valve ?
  • 2,210 Answers
If it is a back flow check valve, then it is designed so water from sink, etc will not flow back into water pipes/system. as long as you do not submerge the faucet into the sink or some other standing water, you will be fine.(and even if you did, the odds of an issue is very very small, if at all). what you removed also could be a flow restrictor and if that is what you removed their is no downside except for more water use.
Posted on May 17, 2015
2 Suggested Answers
  • 2976 Answers
SOURCE: water quits flowing
There is a little popper in the spout area. You need to remove the top handle and slide the spout off. The popper is in the main tube coming up. It.s a standard part at most big box hardware stores and it costs less than $10.
Posted on May 19, 2010
How do you "jump" a water valve?
For testing purposes? If so, you will need to remove the back cover of the refrigerator to gain access to the water valve. Then you will need to disconnect the output line from the valve. If you have another 1/4" piece of water line that you can install on the valve with the other end in a bucket to catch the water during the test that would be great. Now, disconnect the four terminals from the valve. Next you will need a power cord that can be plugged into a wall outlet and the other end needs to be stripped. If you have some female spade connectors to install on the other end of the valve that would be great as well. Now, safely connect the stripped or terminaled ends to the water valve and then plug the power cord into the outlet and check for water flow coming through the valve. If you do have water flow then your next step will be to check the water supply line going from the valve to the icemaker fill tube. It may be frozen.
Jul 07, 2014 | Kenmore Refrigerators
Slow water flow
I would try the backwash as you suggest. Also, I had to run a few gallons of water through a new filter, for it to work properly..
Hope it helps.... good luck!
Jan 12, 2014 | Frigidaire Refrigerators
Very little cold water flowing. Hot is fine. Checked lines--all flowing great.
Remove the cold water line from the rear of the washer.
Remove the filter screen from the water valve and clean it.
A straightened paper clip works good to remove the screen.
Replace the screen after cleaning or you will damage the water valve running with no screen.
Jun 15, 2011 | Maytag Washing Machines
Water flow is slower than the normal. we check the saddle valve, lately we changed the water filter from that day on water flow is very slow.
In some models it creates an automatic by-pass when the filter is removed. If this is one of those models remove the filter and use the dispenser with it out. If you get good pressure now, it indicates a problem in the filter housing. If it's still slow it could be due to low supply water pressure or a defective valve. You can check the water at the valve inlet and outlet. First turn the inlet (main) water supply valve off. Now disconnect the water inlet line at the valve and place the end of it in a pitcher. Turn the water valve back on and check if there is a good solid water flow. If the water flow is good reconnect the water to the valve and now take the water line loose on the back side of the valve. Activate the water dispenser and check how the water flow is coming out of the valve. You will probably need another person to help you with this check. If the water seems slow, then the valve will need to be replaced.
Jan 16, 2011 | Maytag MZD2766GES Side by Side...
GE Profile Side by side model number TFH22PR. Works great, but ice maker not working. It produces water from door just fine, but no ice. What's up with that? Clogged somewhere?
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | GE Refrigerators
The problem that I have with my washer is that water system fails, nowadays already it does not close the water automatic, and previously the flow of cold water was poor for what always was using cold...
Hi and welcome to Fixya. It sounds like you have debris in the water valve inlet screens. Possibly inside the water valve itself. Here is a procedure you can do to try and reverse flow / clean the water valve.
Get a 3 gallon bucket...Turn off both wall connected hoses.
Remove ONE hose from the wall shut off valve and place it in the 3 gallon bucket.
Turn on the hose that is still connected to the wall shut off valve.
Select WARM on the temp selector.
Let the water back flow until the bucket is about 1/3 full. While the water is flowing use the handle of a screwdriver the GENTLY tap in the hose connection at the washer water valve several times to free or loosen debris.
Reverse the hose positions on the wall shut off valve and repeat above until the bucket is 2/3 rds full.
Then turn off the water at the wall and disconnect the hoses from the water valve ONE at a time. One the hose is removed take out (remove) the metal inlet screen from the water valve. You have to use a blade or a scribe on the very outside of the screen to remove it. Take the screen to a sink and using a slow flow of water clean the screen with your fingers / fingernails until you can see through it when you hold it up to a light. Once clean press the screen back into the water valve and then repeat the remove and clean procedure for the other screen.
Reconnect all hoses
Turn on the water and test for leaks.
Check water flow during the fill. You see a remarkable difference.
If there is no change then there is still debris in the diaphram of the water valve. Most often you can not open the water valve and it must be replaced.
Thanks for using Fixya! Kelly
Feb 08, 2010 | Washing Machines
Hooked up new dishwasher and no water to it when turn it on.
Sounds like you're a real DIY (do-it-yourselfer)....great!
Try these steps:
Turn off the water supply valve to the dishwasher. Disconnect the water to the fill valve. Place a shallow pan under the water line and open the water valve slowly. If you have water flowing up to this point, check the power to dishwasher. If no water, check the water supply and anything that might keep water from flowing.
If you have water, then look at the inlet screen to the water fill valve. Sometimes, when a new water supply is hooked up, some sedimentation occurs and gets into the inlet screen at the water valve. Check this and clean it out as needed. Not all units have these screens.
Make sure you have removed any shipping plugs or other items that could prevent the unit from operating.
Jan 13, 2010 | LG Dishwashers
Ice maker stopped making ice
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | LG LFX25960ST Stainless Steel French Door...
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
Plumbing Logo
566 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
