Question about Speco VL565PIR - Cctv Camera With Non Working Pir Motion Detector
Camera portion does not work. brand new units. this has a working pir. light works when motion activated but i have no video.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 33 Answers
Refer to manuals, if you are operating propely then it must be a faulty set since it's a new one
Posted on May 12, 2015
Why is the LED light completely off after the walk test and lockout time?
Yes, it works normally. Things have evolved in the technology of security systems and now it is standard to have any LED turned off on any motion detector (the LED's are now used for walk-testing only), the standard DSC and Honeywell wireless motions also do the same thing.
  • This is a normal function for your motion detector. It's also a great power saving function since most of the current draw on the batteries is when it's transmitting a detection signal so if you're home and moving around it will only transmit every few minutes instead of every second, saving on battery life significantly (up to 5 years on average) but after the 3-minute lockout the passive infrared scans continuously until it transmits another motion signal.
Reason: most burglaries are done by someone who has been there before, if they see the LED then they know the motion will catch them moving in that given spot, then they can "map-out" where it's safe to walk (where the LED doesn't light up) for when they plan to return for a robbery.
You can also make this device "more sensitive" by moving the jumper pin position by the right side battery and having the back mounting plate mounted using the bottom screw presets so it faces slightly downward instead of straight forward.
Helpful tip: Change the batteries every 4 years if you're using Alkaline (dead or not) since the detector was engineered "too energy efficient" and the batteries actually leak and corrode the interior PCB at about the 5-year point on about 15% of the detectors with factory original duracell batteries (from what I've experienced in field service).
Apr 06, 2015 | Interlogix GE SAW Wireless Indoor PIR...
PIR MODE SET UP
I use mine set up for motion sensitvity..this means something must enter the units field of view to be photographed..I set it for maximum distance and to take a photo every couple of minutes..I use an sd card thats 2mb yours may use a 4 6 or 8..look into the window display and see how many photos it will take..mine will do 3000 on the 2mb card..make sure the card is unlocked before putting it in the camera..and you have new batteries in it..
Jan 15, 2014 | WGI INNOVATIONS Video Cameras
Motion sensor light
Just ignore the fact the new device does not have white neutral. While old device has neutral
Difference: The new device is rated for incandescent only, while the old device was rated all type of lights including cfl etc.
Copy following link for wiring illustrations
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
Check manual for product rating. You might want to return device and buy one with white neutral wire so it will work with your application.
Jun 10, 2013 | Leviton R01-PR180-1LI Decora 180 Degree...
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
LED motion sensor lamp, after installed, does not turn off, it is on all day long
usually motion sensor led lamp is a little different from general led lamp. the work condition will shift from general lighting to motion sensor light. The reason why installed, but can not turn off, might you install in the wrong way. You can see the installation details Pir Sensor Led Tube 4ft f328a61c-a223-4610-b54f-1ba4836154f7.jpg
May 28, 2012 | Home Security
I have a Bravo 3P pet immune PIR and it says on the connector that the contacts are normally closed. Unfortunately they are normally open. Is there something that I am missing? Even the specs on the...
To work properly, this unit has to have normally closed loop circuit. With power applied, and no motion in its sight, should measure 000 ohms (plus any resistor value in series). When activated..the contact should show infinite resistance(open).
You are only missing something if you're testing it with you in the the motion area.
Trash it otherwise.
Aug 20, 2011 | Bravo Sports Dsc Bravo 3p Pir Motion...
PIR is only working at about 1ft from unit how can I change this
It sounds like it may be bad. Typical PIR sensor's range is determined by the lens. It's possible it may need cleaning. Most have the front half of the PIR snap on or there will be a screw in the bottom. Opening will allow you to check behind the lens for spider webs or other obstructions.
Good luck.
Mar 17, 2011 | Home Security
Wiring diagram 3 way motion detector switch I want the motion detector to be in the hot line box, and I want a regular 3 way to turn the light on from the load box. So far I can only get the motion...
Sorry, but you need one extra wire between the switches to wire "the opposite configuration" that you want :-(
That means going into the attic and pulling another cable :-( I can walk you through it if you are willing to do all that work.
The only other solution would be to purchase the commercial version of that motion switch, which would also require a sensor at _each_ switch location :-(
Jan 02, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
My motion sensor stopped working--the lights are full on all day.
Good Morning -
Make sure the bulb is point in the right direction and don't use an incadescent? bulb like a 60 watt bulb.
make sure you use floodlightor spot light bulbs so theydon't shine on the sensor.
Have a Great Day!!
Dec 09, 2008 | Electrical Supplies
Speco VL565PIR - Cctv Camera With Non Working Pir Motion Detector Logo
329 people viewed this question
Top Speco Cameras Experts
Steve
Are you a Speco Camera Expert? Answer questions, earn points and help others
