Question about Wolff Health & Beauty
Where can I find a wiring diagram for a 1994 sunquest pro 24 s by Wolff system
2 Suggested Answers
  • 8 Answers
SOURCE: Sunquest 24 tanning bed fan comes on but bulbs
Sounds like there's a short somewhere. You will probably have to have a pro look at it :)
Posted on Jun 16, 2014
I need to move my sunquest pro 24 but its to big to go through door.
Vera, take pictures as you dismantle and label the parts with masking tape and marker, so you will have no problem reassembling. pay special attention to plugs and wires.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Wolff Sunquest Pro 24RS 220 Volts
1987 sca 24 series 1tanning bed manual
I have 1987 SCA-24 series 1 wolffsystems tanning bed how do I change the bulbs or where can I get owners manuel?
May 29, 2014 | Wolff Sunquest Pro 24RS 220 Volts
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
BALLAST FOR PRO 24
A trained technician should: Turn off power to bed. Remove top or bottom cover as necessary, Locate bad ballast, Insert small insulated screwdriver into slot on end of ballast and pull out wire, Remove one screw that holds ballast in place and loosen the other screw, The end of the Ballast should be slotted - so pull it out from loosened screw. Now reverse the process to install new ballast. After remounting ballast to bed, simply push the wires back into small holes in connector.
I lost my tanning bed hinges to my sun quest pro 24 rs.
You are better off buying new hinges. Call manufacturer.
Sep 21, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wiring home tanning bed
If you are installing a bed in your home for the first time, you should have a trained technician to do it, or bad results can happen. Be sure the voltage is correct to the bed - very important. All local wiring codes should be followed for safety - you don't want to kill anyone or the bed.
Sep 02, 2012 | Wolff Sunquest Pro 24RS 220 Volts
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wiring diagram for sunquest pro 24 tanning bed
I do not have a diagram, but the contactors are really simple. You have 2 power switches on top of contactor and 2 wires going to the coil. There should be 4 larger wires on top, 2 in and 2 out.
If any of the crimp-on wire fasteners are blackened, then have a trained technician to replace the fastener. If bed comes on when pushing down on contactor with a plastic ink pen, then check the timer by turning on the timer and checking the voltage at the Main Relay Coil. If no voltage, then the timer is bad.
Jul 31, 2012 | Wolff Sunquest Pro 24RS 220 Volts
I need a owners manual for a Sunquest Pro 24 RS, Wolff Systems tanning bed
Have a trained technician to look at it. You probably have a loose wire nut in the wall box if it is hardwired or a loose connection on the wall receptical. The screws on the recepticals can come loose when pushing the receptical into the wall box. Most new construction uses plastic wall boxes so shorting out the receptical screws to the box should not be a problem. It is possible that the bare ground wire inside the box is hitting one of the receptical screws. If so, then push the bare wire away from the screws with an insulated screwdriver.
Jul 22, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Health & Beauty Logo
35 people viewed this question
Top Wolff Health & Beauty Experts
Steve
noel
noel
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
