Fabric Softener is left behind in the Fabric Softener Dispenser. How many holes are supposed to be open above the Fabric Softener Dispenser?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
If its a front loader remove drawer clean well
Posted on Apr 27, 2015
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
The fabric dispenser does not release softener into the tub
it may be the water supply to take the fab cond in is either blocked (holes) above the dispenser or the water valve is faulty.
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Automatic fabric softener dispensor not emptying
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle)by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Feb 15, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
