Question about Dryers
The top right side and the right side of the get very hot when drying clothes
  • Dryers Master
  • 5,323 Answers
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
The top right side and the right side of the get v - 25667187-hed3japwagud3imxwy3n1koj-1-0.jpg
25667187-hed3japwagud3imxwy3n1koj-1-2.jpg The top right side and the right side of the get v - 25667187-hed3japwagud3imxwy3n1koj-1-5.jpgt/uploads/images/25667187-hed3japwagud3imxwy3n1koj-1-5.jpg" alt="25667187The top right side and the right side of the get v - 25667187-hed3japwagud3imxwy3n1koj-1-9.jpg"h_mi" />
The top right side and the right side of the get v - 25667187-hed3japwagud3imxwy3n1koj-1-20.jpgages/25667187-hed3japwagud3imxwy3n1koj-1-14.jpg" alt="25667187-hed3japwaguThe top right side and the right side of the get v - 25667187-hed3japwagud3imxwy3n1koj-1-27.jpg
Posted on May 16, 2015
mikedurland
  • 481 Answers
SOURCE: Kenmore Dryer model 41783142300
this is an airflow problem. make sure you are using a rigid metal duct behind the machine and not a flexible one. clean out the exhaust duct behind the dryer and in the wall all the way to the  outside. any residue of lint inside these ducts will increase drying time dramatically. basically clean everywhere the air flows.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
  • picture is from fixitnow.com
Posted on Jul 21, 2008
  • 126 Answers
SOURCE: Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Posted on Jan 08, 2009
  • 117 Answers
SOURCE: dryer is hot on tpo
You should check to make sure you don't have a kinked or obstructed exaust line . The exaust is what allows the air from the clothes to escape as well as moisture and heat and is very important for efficient drying.
Posted on Jul 25, 2009
carlsbiz
  • 1124 Answers
SOURCE: dryer is very hot on the right side
It is normal for a dryer to get hot at certain spots.. That means that the heat is passing through close to that area..
However - if it seem too hot - check the vent hose in back and be sure it is not squished or kinked.. Also check the outside vent when it is on to be sure the aire is flowing out properly.. If not - there could be a clog in the exaust..
Posted on Sep 21, 2009
  • 8404 Answers
SOURCE: The dryer is not drying the clothes. It takes two
I suspect your exhaust is clogged. Check it thoroughly! This could be a fire hazard. Check the lint filter, the entire length of the hose and the flap on the outside vent. If your hose is plastic, please have it replaced with a new aluminum exhaust.
Posted on Sep 25, 2009
Does not dry cloths. dryer gets hot,top and sides during drying cycle. it takes 2-3hrs to get cloths dry.
most probable cause of heating yet not drying in a crushed or restricted vent (imagine only inhaling while breathing yet not never exhaling)
Jul 22, 2011 | Kenmore Washing Machines
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
The dryer heats up all right, but the clothes just don't get very dry
Air flow. you need air flow out of the vent to out side of house. Blocked venting will cause hot clothes but still wet.
Dec 01, 2009 | Dryers
Dryer is hot on tpo
Jul 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Dryer doesn't get hot and dry clothes
Open the door.
Remove 2 screws at the top of the door opening.
Remove the top lid, by pulling forward and off.
Look inside right and left top sides of the front panel and remove 1 screw on each side.
Remove the door.
Apr 09, 2009 | Hotpoint Dryers
WHERE DO I FIND THE HEATING ELEMENT ON A ESTATE DRYER
i have a estate dryer it blows hot air and drum turns but does not dry the clothes so it takes 3-4 rounds to dry the clothes what cold be the promblem
Nov 05, 2008 | Kenmore 63942 Dryer
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
Mike
Jul 21, 2008 | Kenmore Dryers
Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Jun 25, 2008 | Kenmore 62802 Electric Dryer
Dryers Logo
Top Dryers Experts
