Question about Garden
Starter rope will not retract - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Sounds like the spring in the recoil starter broke. they usually break on the very end where they bend around connect. I have bent a new 'catch' on the end and got it to work.
Posted on Jun 06, 2015
5 Suggested Answers
  • 6 Answers
SOURCE: starter rope not retracting
open up were the line goes into the blower,u have to rewind it by hand
Posted on Mar 20, 2009
  • 11 Answers
SOURCE: starter rope will not retract
Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
Posted on Oct 25, 2009
bbreton
  • 437 Answers
SOURCE: The starter pull rope will not retract
The recoil starter spring may need to be replaced or the starter pulley has become fused to the plastic housing. If it is not under warranty; taking to a shop to get fixed may be more than what you want to spend. It may be time for a new one.
Good Day.
Posted on Oct 26, 2009
SOURCE: Starter pull rope will not not retract
take off pull mechanism, take out rope and recoil spring, reinstall starter rope
Posted on Jun 28, 2010
Pull cord jammed in the lawnmower
There could be several reasons for this problem, but sometimes it is in need of a simple cleaning. Remove the 3-4 nuts holding the starter assembly on the top of the engine. Normally you will use a 10mm socket and ratchet to remove them. Turn the starter over in your hand so that you are looking at the starter pulley. Inspect the starter rope and make sure it isn't jammed between the starter pulley and the housing. If it is jammed, grab the starter rope and starter pulley and rotate them both together clockwise until the rope becomes unjammed. If the rope isn't jammed, turn the starter pulley counter clockwise gently. It will probably spring back and draw in the rope. If it retracts the rope slowly, spray WD40 around the bolt in the center of the pulley and work the pulley back and forth until the pulley frees up. If it doesn't free up or this isn't the problem, get back with me and I'll try and walk you through the rest of the repair.
Sep 13, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Attempted to start unit, second pull, the pull rope seized up and would not release or retract. Approximately a foot of rope hanging loose.
    It has either broken the starter spring, or the pulley has jammed in the flywheel, remove the cover screws and take away the starter, if the c ord then retracts it was jammed, if not, slacken the centre fixing screw, does it retract now , if so the centre post is worn, and the fixing screws is clamping the pulley before it bottoms out on the top of the post, if it still does not retract, remove the centre screw and pulley, check the spring behind has not broken, be careful as it is a long spring under tention.
    Jul 19, 2011 | Poulan 14" Chainsaw
    Starter pull rope will not not retract. how do i fix
    Jun 02, 2010 | Homelite Consumer Products MightyLite...
    Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
    Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
    remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
    Oct 22, 2009 | Craftsman Garden
    Troy bilt string trimmer starter rope
    you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
    Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
    Starter rope will not retract.
    inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
    Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    Pull cord on chain saw will not retract.
    Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
    Jan 02, 2009 | Husqvarna Chain Saw 20" Bar
    Garden Logo
    96 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
