Lights come on but water says fill - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inlet valve
Posted on Apr 26, 2015
Water is filling up but dont stops and start owerfloawing.Indicator lights are ok but durinig owerfllowing lights disapiered.Float switch is ok what stops water.Is it pressure switch?Thank you.
there is a solenoid that is activated by the float switch
that solenoid cuts off the water
the unit may have a split diaphragm in it and is inoperative in stopping the water in
Oct 02, 2016 | Dishwashers
Kenmore 21102010 lock light and fill light on does not fill just clicks
This sounds like a fill valve problem ,where solenoid is not working. Fill valve is on upper left or right side on rear of machine. These problems tend to occur with hard water. GOOD LUCK FRIEND.
Oct 16, 2014 | Kenmore Washing Machines
Why is my dishwasher not filling with water?
Fill the tub up using large pots of water if it runs but doesn't fill back up for the rinse cycle then you need a new water valve
May 10, 2014 | Maytag Dishwashers
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
