Question about Sewing Machines
Quilting Foot Does the darning foot work as a quilting foot?
  • Sewing Machines Master
  • 1,860 Answers
You have to check in the operation manual for the machine
Posted on Jun 16, 2015
How do I set the Husqvarna 300 sewing machine to do free motion embroidery. Do I need the embroidery attachment and get the machine to embroider with or with out the card
You can do embroidery or you can do free motion. If you're quilting a quilt sandwich (fabric, batting, backing fabric), you probably want to do free motion quilting. Embroidery would work better on fabric (with a stabilizer) but without the batting and backing fabric.
For free motion, you want a free motion foot--your machine's manufacturer probably provided one in the accessory kit (called a darning foot) or there are many generic free motion feet available for purchase (ie Big Foot quilting foot...). The BIG difference with a darning foot or free motion foot is that the shank is shorter than other presser feet because there needs to extra space between the presser foot and the needle plate so the quilter can easily manipulate the fabric. Usually, free motion quilters will drop the feed dogs to avoid feed dog interference with the fabric's movement, however, some quilters don't drop the feed dogs--just whatever works best for you and your machine. In addition, I use a Supreme Slider on the sewing machine surface--a silicone mat that provides a slick surface to help the fabric move.
There are a lot of web sites and video tutorials on free motion quilting. Take some time to watch them and then practice, practice, practice! It's an acquired skill so the more you practice, the better you will be.
Feb 09, 2018 | Husqvarna Sewing Machines
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
How do you set up a brother XL-5700 for free motion quilting
Be sure to have a darning foot or free motion quilting foot (this presser foot is shorter in height so when you lower it, it will not press the fabric to the feed dogs). The foot must allow space under it so the fabric can be manually moved.
The last step is to lower the feed dogs so they are not interfering with your manual manipulation of the fabric.
Lots of web sites about free motion quilting.
Learn How to Free Motion Quilt Stippling
May 05, 2017 | Brother Sewing Machines
I want to free hand machine quilt - but it won't work when I drop the foot
You need an embroidery foot, that doesn't lay on the fabric like a normal foot and allows free motion of the fabric. If you are using one, be sure it is the appropriate foot for your machine and that you have pushed the appropriate button or place on your machine so that the machine will place the foot in the correct position.
Feb 16, 2017 | Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
Open-toe darning foot skips all stitches....help!
Hmm, have you installed a brand new needle? Make sure the needle is compatible with the thread and fabric. Sometimes a top stitch or microtex needle will work better for free motion quilting or darning.
https://www.superiorthreads.com/education/what-causes-skipped-stitches
https://moonlightingquilts.wordpress.com/2012/04/19/skipping-the-skipped-stitches-in-your-free-motion-quilting/
https://www.generations-quilt-patterns.com/skipped-stitches-driving-you-nuts1.html
Feb 26, 2018 | Kenmore Sewing Machines
There is a loud squeaky noise when machine quilting a meandering stitch with a darning foot. The feed dogs are down, stitch width is 0, length stitch is 2.5. The machine does not squeak when using regular...
Is the darning foot aftermarket or genuine darning foot for your particular model...If it is aftermarket, it may not be the correct length. What is you model?
Jul 23, 2011 | Kenmore Sewing Machines
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
