Question about Mtd 22" Yard Machine Push Mower
What is the spark plug gap supposed to be? - Mtd 22" Yard Machine Push Mower
    Novelist:
  • 174 Answers
Spark plug gap is perhaps the most unimportant spec ever.
I don't know of any power mower that won't work just fine with a spark plug gapped using a dime.
Posted on Apr 26, 2015
  • 696 Answers
Hi
If you enter your model number (and serial number if you have it) at the link below, you'll have access to your owner's manual which will tell you what your spark plug gap should be.
Hope this helps.
-Steve
Operators Manual
What do the spark plugs gap set on a 2004 nissan quest 3.5L?
the nissan 3.5 ltr engine says in my manual ngk plfr5a-11 plugs gap 1.1mm
Dec 04, 2017 | Nissan Cars & Trucks
What is the gap size on the spark plug
How far the diode is to metal arm.
Sep 18, 2015 | Cars & Trucks
I was told the spark plug gap was supposed to be 42
spark plugs are not as critical as in the older point controlled systems
the gap increased the resistance to the spark to jump and so gave a hotter spark when it occurred ( same as putting a button in the copper wired lead to burn oil on the plug)
as modern vehicles use a much higher voltage ( early 16.000 volts ,late 60.000 volts ) the the plug gap went from .025" to .050" for a better spark front to ignite the mixture
the correct gap for your vehicle can be obtained from plug catalogs, parts dealers , service shops
it is more important to use the correct HT leads as recommended by the manufacturer as there are variations of internal resistance in the carbon track in the lead that will affect the spark
Aug 28, 2015 | Cars & Trucks
Spark plug gap Champion RJ19LM /E3 plug E3.10
Most small engine spark plug gap is suppose to be set at 30 thou or76 MM
May 02, 2015 | Garden
Spark plug gap on a 2009 yamaha vino 125
I would try 30 . But you can check manual, or web for specific model.
good luck
Jerry
Jun 10, 2012 | 2009 Yamaha Vino 125
240 s chainsaw no spark anytime,point gap fine ,air gap fine,all connections tight,clean of dirt and grease,I suppose it is looking like a new coil which is no longer available!
Hi, screw out the spark plug and plug in the spark plug cap (connect to the coil wiring), then touch the metal part by the spark plug tip, and pull the manual starter and see whether there is spark between the two poles of the spark plug (at the tip), then you can define the problem in which side. (wiring side including the coil or the engine side).
Oct 09, 2011 | Garden
What is spark plug gap for 2000 ford focus lynx ghia 1.6l gas?
It really depends on the spark plug being used. But if you stick to the origninal spark plug NGK TR5A-10 it is supposed to be gapped a 1.0 mm since Ford has issued an in house service directive to reduce the gap from 1.3 mm (original) to 1.0 mm (present) 0.03936996
Kelly
Apr 24, 2011 | 2000 Ford Focus
Spark plug gap?
you usually dont have to worry about the gap. but when you buy the plugs from the store they can tell you if the gap is already where its supposed to be or if you have to gap them yourself
Apr 14, 2011 | Mercedes-Benz 300-Class Cars & Trucks
I changed my spark plus and noe my k-1 will not start. what is the correct spark plug gap for it. and if that does not work what should i do next
Spark plug gap maladjustment will not stop the engine from starting. It will however produce misfiring or rough idle. More than likely, a spark plug cable has stopped making contact. Check the cables for continuity from the coil end, to the spark plug cap end. And also, if the spark plug terminal at the top is making contact with the cap. Check if your plugs are supposed to operate with the bare screw, or the adapter cap.
Dec 06, 2009 | 1989 Honda CBR 600 F(1)K
Mtd 22" Yard Machine Push Mower Logo
316 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
