Remove window, remove track and motor, remove motor from track. reinstall track, reinstall window, push window up into place, cut stick to fit from bottom of door housing to window track, to hold window up with stick. HOWEVER, taking wires from the battery to motor terminals first may start the motor and roll it up .till u get a new door switch
Have someone push button at the same time pull top of window up. Or rake door panel off and reach inside door and push bottom of window up while pushing button
SOURCE: removing the 2.7 engine from 2001 sebring sedan?
ok heres the simple version its alot of work
remove hood put someplace safe
disconnect all wireing and mark off with masking tape and marker
****** you need car lift ******
remove all plastic part molding from engine
find the engine hoist holes for chain to hook to
this is a unibodi design so the whole front chassis drops down
unbolt the chassis make sure to have the chasis blocked and stable
lift car while chasis stays on floor engine tranny and every thing inside hood comes down on the unibody this is how you remove an engine from a sebring
or you take to the dealer spend the doe cause you got a nice car and have it done right
SOURCE: no power to cigarette lighter, and no fuses
Did you check the fuses under the hood? The cigarette lighter fuse is not located in the fuse box by the passenger door.
SOURCE: 2001 Chrysler Sebring- difficulty steering,
the belt will be on the front pulley on the power steering pump
SOURCE: How do I replace the window motor in my car?
take the door panel off...should be 3 bolts holding motor inplace and wiring to unplug...make sure the window is up when attempting ...its not as difficult as it seems thanks and have a good day
