Cannot get a picture on monitor - Computers & Internet
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
My monitors7540 sow menu and blinks frequently
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 18, 2010 | HP S7540 17" CRT Monitor
Nokia 800+ monitor - screen is blinking approx.
Take care.
Jul 17, 2010 | Nokia 800 PRO+ Monitor
I have a samsung 920NW Black 19 monitor that will not stay on beyond 2-3 seconds. I've check cables and tried on two different computers with same result. Is the monitor ready to be trashed? I found a...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault. It can be repaired, all you need to do is just to replace the picture board on the monitor, after replacing the picture board, you will see that the monitor will work fine, just as before.
Take care.
Jul 17, 2010 | Samsung SyncMaster 920NW Monitor
Computer screen has experienced a white out
The problem looks like the picture board on you monitor is malfunctioning or let me put it right, the picture board on your monitor is bad that is why you have a blank screen on the monitor, i suggest you replace the picture board on your monitor in other to get it to display.
Replacing the picture board on your monitor will solve the blank screen problem.
Take care.
Jun 30, 2010 | Soyo 19" LCD Flat Panel Monitor
Will not hold picture - picture distorted
If your monitor will hold pictures and your the screen is distorted, this is a sign that the picture board on your monitor is bad and will need to be replace in order to fix the problem.
Replace the picture board on your monitor to solve the problem.
Take care.
Jun 25, 2010 | IBM G54 Monitor
No picture monitor led is glowing
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but black screen, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 09, 2010 | ViewSonic VP920b 19" LCD Monitor
The monitor keep going to black when its still on.
Take care.
May 10, 2010 | Dell E228WFP LCD Monitor
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
The monitor will come on but screen do not show.
The picture on your monitor won't come on because the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix yourself.
Good luck.
Apr 15, 2010 | HP W2007 LCD Monitor
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
