Question about Sony Audio Players & Recorders
Hi I can't get my Sony MDR-RF810R wireless headphones to work. The light comes on ,on the charger base but not on the headphones. Any idea's? Thankyou
SOURCE: logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Posted on Mar 19, 2008
SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
Posted on Nov 14, 2008
mastersaintx
  • 928 Answers
SOURCE: Sony MDR-V500 headphones: Cushions falling apart!
You can go to Radio Shack and find some that fit. Although Sony does not sell them as they woudl ofcourse want you to purchase new ones you can buy third party cushions that fit.
Posted on Nov 26, 2008
SOURCE: logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Posted on Feb 28, 2009
  • 4 Answers
SOURCE: How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Posted on Apr 03, 2009
Sony MDR-RF4000K wireless headphones
Probably a bit late for the original poster, but just in case anyone else comes across this....
I also have the Sony MDR-RF4000K wireless headphones and the problem with the sound cutting out has got steadily worse over time, to the point where I felt like throwing them away. I replaced the batteries (use normal rechargeable AAs with a bit of card to trip the little switch that would normally be tripped by the Sony battery pack), however that had no effect on the problem.
After a little research I have established that the power on the headphones themselves is triggered by a pull switch in the right ear cup. When you put the headphones on, the padded headband is stretched and pulls the switch up, turning the headphones on. The headphones have always been a little big on me, and I can imagine that the headband has stretched permanently in the last few years, probably leading to the switch on being more marginal.
At any rate, although I don't have a fix, I now know that if the sound cuts out, I don't need to take the headphones off - just pull the headband up slightly on the right-hand side, or push the headphones as a whole down a bit, again on the right-hand side.
Jan 15, 2013 | Sony MDR RF4000K Wireless Headphones
Sony wireless headset for PS3 will not charge
Check for dirty contacts on the charger base.
murf427
Aug 29, 2012 | Sony Wireless Stereo Surround Headphone...
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
I have bought a pair of Sony wireless MDR-RF810RK, and after five to ten minutes of listening ,the transmission fails and the light switches off. If I switch on again it recommences for some...
Hello!
I must inform you that most of the wireless headphones has an automatic shut-off which puts it in stand-by when there is no sound going in to it. Or if the sounds in your device is too quiet the headphones will think you have finished using it.
What you need to do is increase the volume setting of your device. And turn the volume control on the headphones down then as well - assuming that your headphone base unit is connected to the headphone socket of your device.
ALPUG
If this will help, please give this answer some ratings!
Feb 24, 2011 | Sony MDR-RF970RK Headphones
Are the MDR-RF925R useable with TV's
You can use MDR-RF925R with any thing that has Line Out RCA jacks and your tv should have TV Audio Out RCA jacks to connect this wireless headphone.
Thanks.
Jan 04, 2011 | Sony MDR-RF970RK Headphones
Where can i get a replacement rechargeable battery thanks
You can actually use two regular dry AAA batteries to power these headphones, the only thing is that you will not be able to charge those batteries with the charging station that comes with the headphones.
Feb 01, 2010 | Sony MDR-RF970RK Headphones
Hello, I am looking to replace the cord for the now discontinued Sony MDR CD780 headphones. The part # is: 179244711 and they are really hard to find. Any ideas how I can replace these? Are they...
Have a look at this:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/ I hope it helps. You can purchase parts at any good electronics store.
Nov 19, 2009 | Sony MDR-CD780 Consumer Headphones
Sony mdr-rf970r does not work, there is a lost of static and i can faintly hear the music!!!!
make sure your not using them anywhere where theres a lot of electrical equipment around, it sounds silly though their prone to interferance so take the base and place it away from any other equipment and see what happens, hope this helps :-)
Aug 04, 2009 | Sony MDR-RF970RK Headphones
Sony mdr v150 wiring plug adaptor 4 wires green,
The green wires go to the left channel (Plug tip). The red wires go to the right channel (plug ring 2 band from tip) and the brass wires go to the ground (sleeve plug base).
May 05, 2009 | Sony MDR-V150 Professional Headphones
154 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
