Question about Cuisinart Food Processors
Will cuisinart DLC 8F discs fit new models - Cuisinart Food Processors
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart DLC- 8M
Those older Cuisinart food processors have motors that generally last forever. But a replacement bowl can cost $118.00 or more. The newer processors like the DLC-8S do have a 3-year general warranty and a 5-year motor warranty. The new DLC-2011, 2007, 2014 series etc. have 10-year motor warranties. I like the collect the oldies, but the new ones have few problems even though they are made in China. If an old processor's plastic breaks, you have to buy a completely new bowl set - if a new processor's plastic breaks, then you can buy a single component piece to solve the problem. Hope this helps.
-Tha Mp3 Doctor
Posted on Dec 09, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
Cuisinexpert
  • 61 Answers
SOURCE: Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Posted on Aug 31, 2009
kendbin
SOURCE: replace the spindle on Cuisinart DLC-7 Food Processor
You need to pull the old one off, probably with vise grips and a lot of effort, and then order a new one. The new one is a tiny bit larger, so you'll probably need to order new blades, too. The new one slips right on, so there's no issue that would be the reverse of removing the old one. I read somewhere else that you have to pound hard to get the new one on, but that guy must have been speaking about the older model spindles. I was perplexed that the new one slipped right on so I pounded it to be sure and ended up breaking the tip of the new spindle and cracking the housing of the whole processor.
Posted on Jan 17, 2012
My Cuisinart food processor has model #DLC-8F; I would like a new blade mine is cracked.
"fixya" neither has nor sells any parts for anything.
We are a website offering information on fixing things in and outside of the house.
Please type your request into the computer search engine, and you should find a Cuisinart dealer who will help you.
God bless your efforts.
Jan 23, 2017 | Cuisinart Food Processors
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC- 8M
-Tha Mp3 Doctor
Sep 19, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Have a very hard time to snap the top on the food processor same to take the bowl out
thank you for the follow up
the only way to solve my problem for an older model cuisinart basic is to buy at Le centre du rasoir a new bowl and cover for the model DLC 10 that should fit
have a good day
Sep 07, 2008 | Cuisinart DLC-5 Food Processor
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
Food Processors Logo
120 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
