Question about Schwinn Cycling
I have plugged in my schwinn 120 and it does not turn on. What may be some problems?
  • Schwinn Master
  • 914 Answers
Check to see if power cables are plugged in, for any loose connections and or any visually crimped wires
You could also try disconnecting from outlet it is in and reconnecting to a new one just to make sure the outlet isn't the problem.
Make sure that your power adapter is supplying voltage to your unit, you could try connecting adapter to a machine you know that works or use a MultiMeter to check for appropriate voltage (please call us for assistance with MultiMeter tests if not sure how to run one.)
Insure your data cable is oriented properly, Small latch on connector should be lined up and snapped into place.
If these steps do not resolve your problem, please give our SportSmith Tech support Team a call and we would be happy to help or check out our Tech support center online
Phone Number is 888-713-2880
Or online http://www.sportsmith.net/supportsearch.aspx
Posted on Jun 03, 2015
Console doesn't work on schwinn 120?
Here is a link to the owners manual. See section 7 regarding the consol connection.
Aug 10, 2017 | Schwinn Cycling
Just bought a 2009 schwinn valo 50, it sparks but doesnt start would it more likely be stator or CDI?
Hi, Kelly and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2008 schwinn valo 50 spark problem Scooter Doc Forum
http://www.manualsonline.com/support/schwinn-motor-scooters
Schwinn Motor Scooters Hope 50CA06PK Manual
Currie Technologies
Schwinn hope 50 User Manual
Mar 17, 2017 | 2010 Schwinn Valo 50
My Schwinn 420 elliptical is not powering on. The breaker and outlet source are fine. When I plug the machine in nothing powers on. The console displays nothing, no lights, etc.
test the power cord plug, in another device and see if working
2) replace batteries if your system has( clean the contacts from oxide,corrosion with contacts cleaner) and try again when you have isolated the problem
God bless you
Nov 05, 2013 | Schwinn 420 Elliptical Trainer
Can you buy a replacement canopy for a schwinn trailblazer?
If you have the old canopy, I can use it as a pattern to sew a new one for you. Mail it to me and I should have one made within a week or so. Cost: $120 + any tax + shipping. I made this replacement for a Burley D'Lite.
Mar 30, 2013 | Schwinn Trailblazer Bike Trailer
The power cord for my schwinn 430 elliptical no longer stays plugged into the machine. I have to push it really had into the bike outlet so the machine turns on, but as soon as I take my hand off of it,...
Do you think the power cord is going bad? If so here is the parts list for the Schwinn 430 if you need to order a new AC adaptor. If you think the connection inside the machine is going bad you may want to find a servicer to look at it.
Apr 19, 2011 | Schwinn 430 Elliptical Trainer
I dont have a problem... I just wanted to know about the 'speaker' (if that is indeed what it is)that came with my Schwinn free runner single lt stroller. Is it for an ipod or what?
The speaker is for playing music but, the Schwinn site doesn't specify what type of a plug it has. Ipods have a long, squarish plug, whereas radios and CD players have a round pin style plug.
Sep 10, 2009 | Schwinn Free Runner Single LT - Blue/Black...
Schwinn s180 wont charge
hi, just plugg it in turn it on. there should be a red and green light on your charger.
Apr 08, 2009 | Transport Schwinn Rechargeable Portable ...
Cycling Logo
67 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
