Question about Pool & Spa
I have a new spa and he says an error E98 by other models it means water to hot but my water is just 13 degrees Celsius how can i fix it ?
    Champion:
    Scholar:
  • 239 Answers
That often happens when there is a reduced flow of water. it heats up too fast and cannot circulate to the spa causing it to overheat when the spa is in reality not hot
Posted on Jan 12, 2016
My Intex portable spa comes up with error E98 when i turn and run. What is this and how do we fix it?
Sounds like bad news?
if you've resolved this, please comment back, and let this forum know your experience - success or : (
Use the comment link.
If your still dealing with this problem and/or for all others who need to contact Intex...
Support Intex
Feb 07, 2015 | Intex Pool & Spa
Spa indicator says Water SW Open...what does that mean and how do I fix?
This means that the pressure switch is not closing. Generally, this is a lack of water flow issue. The main cause is a dirty filter. Clean cartridges, backwash sand, backwash and recharge DE, whatever is needed to clean the filter, this should fix the problem. If not check other sources of restricted flow: filter baskets, pump baskets, shut-off valves. If everything is clear and there is good flow returning to the pool it could be a bad pressure switch. Replace with the correct switch for your heater.
Sep 13, 2014 | Rheem Pool & Spa
Hs error code what does it mean?
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees. Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow condition. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 19, 2014 | Hayward H400FDN Low NOx Natural Gas Pool...
How long does it take to heat a spa pool?
All depends on the amount of water in the spa or pool, and the size of the heater in BTU's. The time for "Heat Rise" will vary and the answer you are looking for can't be provided with amount of info you provided. But if a general rule of thumb - the closest answer: Spa with a gas heater, 1 degree about every 90 - 120 seconds. Electric heater (vary's by KW) on average: cold to hot = 8-13 hours. Swimming pool with gas heater (no suggestion for electric) about 1 degree temp rise every 90 minutes.
Dec 27, 2013 | Pool & Spa
No water flow e90 fault code intex pure spa
Unplug the unit. The E90 code on the intex spa is due to a dirty water flow sensor. Remove the control panel and all the screw holding the casing on. In the white plastic piece on the discharge, top hose, you will see a silver nut with a black wire coming from it. That's the sensor. The black wire is plugged into a white wire, carefully unplug it and unscrew the sensor. Clean it good and blow out the hole it goes in. This will fix the code and you will be back in business!
Sep 27, 2013 | Intex 10x30" Metal Frame Pool w GFCI
Electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Oct 28, 2012 | Electrolux EW1000i Front Load Washer
Water too hot
Jul 20, 2011 | Washing Machines
Converting negative deg F to deg C produces conversion error
If your measurement are negative use parentheses such as, (-4) degrees Fahrenheit converted to Celsius should = -20. Where as 4 degrees Fahrenheit equals -15.5 degrees Celsius. the parentheses are not needed if your measurement is positive.
Dec 20, 2010 | Texas Instruments TI-86 Calculator
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Pool & Spa Logo
125 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
