Question about Plumbing
What is this used for
Im useing it to reduce my pipe from 3/4 to 1/2 inch
  • 2,355 Answers
Thats what its used for.
Posted on Apr 26, 2015
Has 2 inch main water line and 3/4 Inch meter.can I reduce size of pipe to 1 inch
Yes if you reduce the size it will not affect the metre you could reduce to 3/4 and 1/2 for house use.
Dec 18, 2015 | Refrigerators
Can I get more horse power? 1998 Chevy Silverado w/V8 350?
Reducing the pipe diameter will improve scavenging and increase fuel economy at the expense of power large free flowing exhaust is important for max power. If you want more power the simple answer is use the bolt-on supercharger kit available as an after market option.
May 26, 2014 | Motorsports
I have 2 inch PVC system for my pump and filter. Fafco inground system has 1.5 inch piping. Where is the best way to reduce 2 inch pipe to 1.5 inch (at the diverting valve or at the panel)? Another...
Honestly, I think you are over thinking both your problems. Reduce to 1.5 inch pipe as close to the ground as possible. It is more work for your pump to push water up a 2" pipe then a 1.5" pipe, but it will do either without any real problem.
As far as mounting your panels, as long as they are above the water level of the pool the water is going to drain out of them just fine. You can slope them slightly, but you don't need to.
Apr 16, 2011 | Fafco Inground Deluxe Solar Heating System...
Hi, my 200sx has been fitted with an exhaust (not by me) which has a stainless steel 3inch pipe running from the cat-back, but goes in to a backbox which has what looks like a 1, maybe 1 1/2 inch pipe in...
Hi,,,,yes that is a huge restriction and realy insane,,,,,get rid of that pea shooter and put 3 inch,,im suprised it hasnt done any enginge damage.
good luck
Mar 24, 2011 | Exhaust for Nissan 200SX
I just bought it and delivery man said he could not install it because my vent out of the roof is only 3 inches. Can I just use aluminum tape to secure the vent hose?
Local code determines the minimum size for dryer vents. Often this is determined from the manufacturer's requirements for the appliance. As you may have guessed, this is pretty much the standard for dryer manufacturers.
If you were to "adapt" the dryer's 4" pipe down to your home's existing 3" pipe, you would reduce the pipe's area from 12.6 sq inches to just 7.1 sq inches (radius squared x 3.1415). That's nearly HALF the required area that is required. Your clothes dryer will suffer. Drying times will increase dramatically as there will be less air flow. Electric / gas usage will increase due to the longer running times, and there could be significantly more heat inside the dryer that could be a fire hazard.
Don't do it. Either invest in the correct size dryer vent, or use another venting method instead of reducing the pipe size.
I know it's not what you wanted to hear - but I hope this helps. Please rate my reply - thank you.
Mar 09, 2011 | Dryers
What size npt thread is the adaptor
Common American National Standard Pipe Taper Threads
  • NPT - National Pipe Thread Taper
  • FPT - female (internal) National Pipe Taper threads
  • MPT - male (external) National Pipe Taper threads
  • NPTF - Dryseal American National Standard Taper Pipe Thread (ANSI B1.20.3)
For NPT threads a sealant compound or Teflon tape must be used for a leak-free seal. For NPTF no sealant is needed for a sealing.
Characteristics of NPT (also known as ANSI/ASME B1.20.1 Pipe Threads, General Purpose):
  • tapered thread 1o 47'
  • truncation of roots and crests are flat
  • 60o thread angle
  • pitch is measured in threads per inch
Note! Pipe sizes do not refer to any physical dimensions. The outside diameter of a pipe or fitting must be measured and compared to a table for size identification. A 3/4" NPT pipe thread has an outside diameter - OD - of 1.050 inches.
Each thread size has a defined number of threads per inch - TPI, or pitch. The 3/4" NPT pipe thread has 14 threads per inch. Both the TPI and OD of the thread are required for positive identification of thread size because more than one size have the same TPI.
NPT - American Standard Pipe Thread Taper 1) Pipe Size
(inches) Threads per Inch
TPI - pitch Approximate Length of Thread (inches) Approximate Number of Threads to be Cut Approximate Total thread Makeup, Hand and Wrench (inches) Nominal Outside Pipe Diameter
OD
(inches) Tap Drill
(inches) 1/16" 27 0.313 1/8" 27 3/8 10 1/4 0.405 R 1/4" 18 5/8 11 3/8 0.540 7/16 3/8" 18 5/8 11 3/8 0.675 37/64 1/2" 14 3/4 10 7/16 0.840 23/32 3/4" 14 3/4 10 1/2 1.050 59/64 1" 11-1/2 7/8 10 9/16 1.315 1-5/32 1-1/4" 11-1/2 1 11 9/16 1.660 1-1/2 1-1/2" 11-1/2 1 11 9/16 1.900 1-47/64 2" 11-1/2 1 11 5/8 2.375 2-7/32 2-1/2" 8 1 1/2 12 7/8 2.875 2-5/8 3" 8 1 1/2 12 1 3.500 3-1/4 3-1/2" 8 1 5/8 13 1 1/16 4.000 3-3/4 4" 8 1 5/8 13 1 1/16 4.500 4-1/4 4 1/2" 8 5.000 4-3/4 5" 8 1 3/4 14 1 3/16 5.563 5-9/32 6" 8 1 3/4 14 1 3/16 6.625 6-11/32 8" 8 1 7/8 15 1 5/16 8.625 10" 8 2 16 1 1/2 10.750 12" 8 2 1/8 17 1 5/8 12.750 14" 8 14.000 16" 8 16.000 1) The taper is 1/16 inch in an inch, which is the same as 3/4 inch in a foot (angle 1o 47')
NPT threads are not interchangeable with NPS - National Pipe Straight - threads.
NPT threads may look similar to ISO 7/1 threads. However, ISO and NPT threads should not be mixed. ISO threads have 55o taper angle versus 60o for NPT. The NPT root and crest configurations are also different from ISO. For ISO threads pitch is usually measured in millimeters (may be expressed in Inch). The pitch are different.
Feb 28, 2011 | RTO 1 1/4" Drop Pipe Bronze Pitless...
I have a quote from a contractor to install a Rinnai R75 tankless water heater. The heater normally requires 3/4 piping. My home has 1/2" piping. The contractor says 3/4" is better but 1/2"...
There are advantages and disadvantages to both pipe sizes. Typically, most houses utilize 3/4 inch or larger to supply high volume circuits like the circuit from the meter (or well) to the hot water heater, outside spigot, or water softener. Distribution from water heaters is usually 3/4 for the main branch but this is reduced for the runs to the sink, dishwasher, washing maching. The reason for reducing the size is to reduce the volume of water in the tube or to reduce the amount of cold water you run down the drain before it turns hot.
Since your house seems to have 1/2 inch supply to the current water heater, I would suggest staying with the current size. The option is to enlarge the tubing from supply to distribution which can be a major plumbing task. If your current water pressure (at the faucet) is ok, then go with what you have.
Jan 31, 2011 | Kitchen Ranges
I have all Kohler shower heads with 1 inch pipes; none of the currently available products, all at 1/2 inch pipe connections will fit; is there a 1" to 1/2" reducer piece available; Kohler does not have...
their out there 1 female to 1/2 male reducer u can also check for chrome offset reducers used in the antique conversions such as for faucets for clawfoot tubs and the old farmer sinks
May 05, 2010 | Home
LG DLG5988 installation Vent size
The vent is a 4 inch round opening.  Per the manufacturers specifications, you should only use 4 inch solid metal vent pipe, not plastic or metal foil vent pipes.
Nov 09, 2007 | LG DLG5988 Gas Dryer
Plumbing Logo
858 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
