Question about Measuring Tools & Sensors
WHAT KEEPS BREAKING THE FLYWHEEL KEY/ CHANGED IT OUT TWICE. DOESN'T SEEM TO BE ANY DEBRIS IN AREA, DOESN'T SEEM TO BE CATCHING ON ANYTHING
CHANGED OE OLD BROKEN KEY WITH NEW ONE. TRIED TO START IT AND IT BROKE THE KEY AGAIN
  • 3,519 Answers
Hi Tami:
When you replace the key, the flywheel attachment nut has to be really tight so that there is absolutely no slop in the flywheel connection. Give it another try. Don't strip the threads, but also, don't be afraid to pull on the wrench.
Posted on Apr 26, 2015
Flywheel keeps breaking
By breaking I assume you mean into pieces? The only thing that would cause this is a badly misaligned transmission. Any other problems would cause such vibration you would not drive the vehicle .
Oct 14, 2015 | 1986 Ford Ranger 2WD
Why does my Poulan 625 lawn mower when using the key start makes a whirring sound and not start?
maybe this might help, some of the newer engines have an oil alert. if the oil level is low it won't start.
Aug 01, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Flywheel key keeps breaking
Hello Bob
My name is George. I am a repair technician at a local shop here in Hickory N.C.
The reason the key keeps shearing is that the flywheel needs to be torqued to the engines specifications. Once you do this you will be ready to go again.
Thanks for letting me try to help.
George
Oct 22, 2013 | Craftsman Garden
Flywheel breaking
If you aare sure the securing nut is tight, then it has to be a problem with the taper on the crank, it is the taper on the crank that holds the flywheel, the key is just to align the ignition timimg.
Oct 12, 2013 | Garden
Model 31p777 flywheel keeps breaking after i put the key in
the flywheel key keeps breaking or the flywheel itself does?if it's the key the blade might be bent
Jul 14, 2012 | Briggs & Stratton Garden
Replaced starter with a smaller version of the original starter that bolted up but the bendix doesn't seem to be catching the teeth of the flywheel. could it be the "new design" of the...
Count the teeth of the starter the teeth of the starter is different you will need to disasemble the starter and change the teeth over some have 9 teeth and some have 11 teeth
Aug 21, 2011 | 1997 Nissan 200SX
I have threaded up my machine and have started to sew. The thread on the back of the fabric keeps catching and bunches up. What's going wrong?
try a new needle
keep a check on the thread take up lever that the thread doesn't come off of it
rethread the machine to make sure that the thread isn't catching on anything
clean under the needle plate for loose thread or lint & in the bobbin area also
make sure the bobbin is inserted correctly
Aug 04, 2011 | Bernina 1008
Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Breaking thread
Try adjusting the tension in the "Set" menu. "Tweaking" anything else may end up costing money.
First, make sure the hook area under the bobbin case is free of debris. Try a new bobbin and a new spool of thread with a new needle, full inserted. If the needle threader isn't lining up, the needle may not be in right.
Jul 12, 2008 | Husqvarna Designer I
Measuring Tools & Sensors Logo
201 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
