Question about Zoom Music
Zoom G5 multi-fx pedal won't turn on need help please.. so accidentally plugged in the wrong adapter, and now it won't turn back on. Any suggestions or mayb a place I can find the schematic?
    Top Expert:
  • Zoom Master
  • 3,113 Answers
This needs to go to the shop. It'll be easier than trying to track down what all is burnt..
Posted on Apr 27, 2015
bolinlamar
  • 157 Answers
SOURCE: my zoom 505 2 distortion pedal for my guitar will
I have had this same problem with mine, since the adapter jack is loose it's probably broken loose from the circuit board inside. I had to carefully dis-assemble and re-solder the adapter jack back to the circuit board. This is un-fortunately a weak point on some of Zoom's pedals, when you or if you get someone who is good at soldering to do it for you ask them to beef the solder joints up a little to help keep it from coming loose again. I re-did mine and I've never had another problem with it.
Posted on Aug 28, 2009
  • 5603 Answers
SOURCE: Where should the Zoom G1X go in a pedal chain?
From an electrical engineering standpoint, an expression or volume pedal should be near the end of the chain so that the other effects don't try to process very weak signals when the volume is very low.
This gives better signal to noise ratio.
Posted on May 11, 2010
  • 298 Answers
SOURCE: hi my zoom g1x fx is having some sound issues,it
Hello. I am assuming that you are using the manufacturer supplied mains power supply and not running it from battery (otherwise replace the battery before doing anything else). I have noticed a similar problem occasionally with my Zoom G1XN too - mostly when I have been using it with headphones plugged directly into the pedal. Sometimes gently wiggling the output jack plug seems to have solved the problem - however I have had it occur when using the pedal with an amp too. Next step would be to try using different jack leads (or swapping the ends round) to make sure it is not a problem with poor contacts in the sockets. If this seems to solve the problem a little squirt of switch cleaner in the sockets wouldn't go amiss - but leave it 24 hours to dry out before using again. Do you find it only happens on some patches or on all of them? I have one patch that is absolutely clean (straight through with every effect set at flat/zero). Try that with one patch and see if it still does it and to give you a quick comparison. However, I think there may also be a bit of a problem with the effects processor itself (either in the design or the circuitry) - let's face it the GX1 is a modestly priced unit and they probably keep the price down by using cheap components. My usual solution has been to switch it off and remove all the plugs and start again. This has worked but is kind of annoying if it happens in the middle of a gig or half way through recording a song. Lastly I would try re-calibrating the expression pedal. as follows
  1. Turn the unit off
  2. Hold down the PEDAL ASSIGN button whilst turning on the power/ inserting input jack-plug.
  3. Raise the expression fully and press the STORE key (display should read "UP")
  4. Push the pedal down as far as it will go, until it hits the stop, and then release it (it will return slightly at this point)
  5. Press the STORE button again.
  6. If the display reads "Er" repeat the process from step 3 above.
Posted on Jan 30, 2011
  • 298 Answers
Hello I have this pedal too and have experienced similar problems..
If you are using battery power only use Duracell Ultra (or equivalent) never re-chargeable batteries. However I am assuming you are using the mains power adapter rather than batteries.
Start by eliminating external issues. Change your guitar lead and output lead - if you don't have spares swap them over or swap the ends round to make sure it is not a contact issue in the jack sockets.
I found this problem occurred most often when I was using headphones plugged directly into the pedal rather than an amp. I was usually able to solve it by wiggling the output jack plug slightly so came to the conclusion that it was just a poor quality plug or socket.
Having said that I think that there might be a bug in the processor unit itself because I have occasionally experienced the problem when playing through an amp. I resolved it by unplugging everything and starting again but this is a bit annoying either during a gig or half way through a recording session.
Does it do it on every patch or only on some? I have one patch that is completely clean (straight through) with no effects, noise reduction, boost, with the tone set at flat. You could try setting a patch like that up as a comparison and see if it still does it.
Lastly you could try recalibrating the expression pedal.
  1. Unplug the input jack to turn the unit off.
  2. Hold down the pedal assign button whilst plugging the input jack back in.
  3. The display should read 'dn'
  4. Raise the pedal fully and press the store key
  5. The display now reads 'UP'
  6. Push the pedal fully down to the stop and then release it (it will return slightly)
  7. Press the store key again
  8. Job done (unless the display reads 'Er' - in which case repeat from step 4)
  • 5603 Answers
SOURCE: I don't know how to
Most of these the battery is UNDER the pedal itself. You push in on the hinge pins with a pen to release and remove the pedal and change the battery.
Posted on Apr 28, 2011
It blinks with "be" and turns off
It may be "but" that you're seeing, which indicates the batteries are low. Use the AC adapter made just for this model only, and the guitar needs to be plugged in to turn the unit on. A full manual for this Zoom model can be found here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Dec 01, 2013 | Zoom Samson Technology Zoom G1XN Multi...
No power or display when I turn on the gadget, even using battery, it will display sometimes but a blink oh "be" letter appears on the screen
Where can i buy this regulator for zoom g1x?
If it is difficult to find 2933BD/29M33, use MC33269-3,3 for SMD package or LM1117-3,3 for TO-220 package.(datasheet LM1117)
You can find or buy here,in Indonesia:
It's very cheap, about 5000 IDR or it's about half US-$.
I repair musical instrument(guitar fx,amps,keyboard etc).
Visit me here.
Nov 27, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
My g1x zoom pedal turns on but no sound will come out ? HELLLP ASAP.
did you check the instrument cables? could be one or more of them is shorting
Oct 19, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
Hi my zoom g1x fx is having some sound issues,it creates unpleasant noises and the sound kinda fades. I noticed the fading of the sound when i'm picking the thinner strings but it sounds so loud on the...
Jan 30, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
Hi.why my zoom g1x has no power.im using a universal adator...i am in phillpines.power volts here..220 volts.how is the setting of my adaptor then?
I have a ZOOM GX1XN and it doesn't like universal adapters much. Using one with the wrong voltage or polarity may permanently damage your pedal. Try to obtain a proper ZOOM AC adapter (part number AD-0006 or AD-16) if possible. These are dual voltage and will work equally well with both 220 and 110 volts. Failing that you need an adapter that will give a DC (direct current) output of 9 volts at 0.5amps - maximum 4.5 watts. The outer contact (sleeve) of the adapter needs to be positive (+ve) and the inside contact negative (-ve). Lots of universal adapters are the other way around with the sleeve being negative - but some have a multi-connector on the end with both positive and negative sleeves.
Jan 08, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
G1X not working
The first thing to check is the power source. A weak battery or adapter will cause this.
Beyond checking these the only other problems will be internal and require electronic servicing.,
Jul 02, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
Music Logo
299 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
