Question about Boating
What diagram is available for hooking two 12 volt batteries together to create 24 volt power
  • 86 Answers
Http://www.nyc-arecs.org/batt1.pdf
Posted on May 27, 2015
3 Suggested Answers
oldfishead
  • 155 Answers
SOURCE: I have a minn kota 48 AT 12/24 volt bow mount that
use a volt meter and check for voltage at the plug, if none..check in the back near your batterys and locate the circuit breaker and reset it ...basic system = battery-breaker-wires....hope this helps ....GL
Posted on Jul 06, 2009
  • 69 Answers
SOURCE: Have 24 volt system. Seems lack power. Checked
You need to check voltage while under load.
Posted on Mar 29, 2010
How do I wire two tandem batteries for an electric scooter
Tandem batteries... is a fairly loose term to be dealing with on batteries... SIMPLY BECAUSE THEY ARE EXPLOSIVE.
TANDEM voltage
(assuming you were trying to achieve 24 volts with 2
12 volt batteries would NORMALLY be called serial...
Where as to increase AMPACITY ... called "parallel."
Rather than risk severe burn, blindness (end of life
experimenting with EXPLOSIVES...
You need to go back to your source for better information ...
or
Provide better information here... Pretty please
Jan 12, 2017 | Electric Health & Beauty
How can I hook two 12 volt batteries together to produce 24 volt output. I have replaced the two older batteries but have not been able to get the two new batteries to produce the necessary 24volts
Hooking up 2 batteries (IN SERIES) will give you 24 volts. First make sure the 2 batteries are exactly the same. Do not use mismatched batteries. Hook the POSITIVE of first battery to the NEGATIVE of the second battery. Then hook your LEADS ( hot and ground) to the 2 remaining posts. That will give you 24 volts. When charging the batteries with a charger, hook the charger up to the LEAD POSTS.
Apr 26, 2015 | Boating
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
Batteries were dead. put 2 new 12 volt batteries and hooked them up the way the old ones come out + to+ and - to - I turn the switch on and have no lights, no horn , motor won't run. fuses are...
Bob make sure that the wiring is connected correctly to scooter controller in other words if the cables from the batteries have a connector that plug into the harness coming from the controller make sure that connectors (if color coded) match up and that they are seated correctly. Look on the underside of your rear shroud for a wiring diagram and make sure that the new batteries are wired in that way Hope this helps
Jun 21, 2011 | Health & Beauty
I NEED A WIRING DIAGRAM FOR A 120/240/24V ACME CONTROL TRANSFORMER.IT HAS H1,H3,H2 AND H4 ON ONE SIDE(PRIMARY). SIDE 2 HAS X2,F1,F2 AND X2 (SECONDARY). IT CAME WITH NO INSTRUCTIONS AND I NEED TO HOOK IT UP...
If you're wiring up 120 volts to the primary then you need to connect H1 and H3 together, then connect H2 and H4 together. Then connect one side of line (120 volts) to H1 and H3 and connect the other side of line (120 volts) to H2 and H4. Then for the 24 volts secondary X1 is one side of your 24 volts and X2 is the other side of your 24 volts.
For 240 volt primary connect H2 and H3 together, Then connect one side of your Primary (240 volts) to H1 and connect the other side of your primary (240 volts to H4. Then your Secondary 24 volts is still X1 and X2.
May 08, 2010 | Heating & Cooling
My 12/24 volt trolling motor only runs on 12 volts
Did you connect 2 batteries to try the 24 volt version? You have to link them together like a flashlight, positive to neg and then out the other side, for 24 volts, like a golf car.
Feb 23, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Hooked batteries up in series ( 24 volts ) now
sounds like you fried the computer and likely the coil too
salvage yards love people who dont read the chilton books
Jan 10, 2010 | 1991 Ford F150
Wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Nov 05, 2009 | Boating
Battery wiring
Series or paralell?. Should be parallel so you get 12 v0lts. two positives together and two negatives together
Sep 26, 2009 | 2001 Toyota Land Cruiser
Boating Logo
194 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
