Question about Stihl Garden
Have a stihl chainsaw that's probably 10 yrs old. Will start ok but the chain won't move when given gas. It revs but won't move.
  • Stihl Master
  • 2,760 Answers
I guess the first thing to look at is chain free to move ?, do this with saw off ! and not running , if its not free to move give a good look at the chain brake , if chain moves free with a gentle push , then your clutch is in need of replacement good thing as stihl makes parts for there old saws still too , now if your saw was 20 yrs old your clutch is rebuildable
Posted on May 07, 2015
  • 211 Answers
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Posted on Feb 14, 2009
revskank
  • 203 Answers
SOURCE: McCulloch chain saw pro Mac 10-10
if you are using McCulloch oil 40:1
Posted on Mar 02, 2009
  • 323 Answers
SOURCE: chainsaw gas/oil mix ratio
I have two Stihls that are well over 20 years old. I use the factory recommended mixture, 1 part 2 cycle Stihl oil to regular gas. (1:50)
That is still what the factory recommends. Don't use a cheap 2 cycle oil, go to a Stihl store and buy their 2 cycle oil in the orange plastic bottle.
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
Posted on Jun 11, 2009
dontbother10
  • 2220 Answers
SOURCE: i have a stihl 024 av chainsaw. the case hinges
Are you asking about the PVC carrying case? Isn't it possible to mount a couple of small hinges using countersunk screws from inside the case to lock washers and nuts outside the case. Use a file to remove any threads extending beyond the nuts so your leg can't get snagged. It might even be worth adding a couple of countersunk flat washers to the inside of the case. HTH
Lou
Posted on Sep 10, 2009
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Saw will start but dies when rev
Check the pick up fuel line in the gas tank. If there is a fuel filter at the end of the line,remove and clean or replace. Use a small fexible wire to hook line and pull out thru gas tank opening.
Mar 14, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl chainsaw (Farm Boss) - chain oiler has stopped working, how do I check the fault ?
Hi John...
You will need to remove the bar and chain...behind the bar is the auto oiler it works on the shaft of the chainsaw, you will have to remove it and clean all the outlets for the oil to the chain.
Please take time to rate me
Bud
Mar 10, 2013 | Garden
Stihl 009 chainsaw
please provide more info about saw! Your question leaves everything from stuck in a Bee tree to out of Gas. Got your mind on you saw and left a little info out about the saw, it happens. I was put on my first one at 10 yrs old and have used one every year since, i'm 63. Lets fix that Saw!
Gillight
Jun 22, 2012 | Stihl Chainsaw 009-200T (30LP-50)
Scorched pistons in a STIHL chainsaw - and its not the fuel mixture
What side of the piston is scored? If it's the exhaust side, it's running too lean, ergo, it's the mix ratio.
Nov 16, 2011 | Stihl Chainsaw 42mm Piston Rings 025 O25...
I have a Stihl chain saw an O8S. The carburetor
I would try here first. I have had good luck getting old parts here. I hope it helps you out.
www.jackssmallengines.com/stihl_index.cfm
Jun 17, 2010 | Standard Oregon Chainsaw Chain For Stihl...
Stihl saw 026 runs 5-10 min won't stay running and backfires
5 to 10 minutes is a long time and the 026 is a fairly old saw. If it is running 5 to 10 minutes and not 5 to 10 seconds, you probably just have a worn engine. Clean the saw inside very thououghlr and try Amoco white gas. You should be able to reduct the heating and get more run time. A carb rebuild might also help some but in hot weather it is not unusual for chain saws to vapor lock.
Sep 21, 2009 | Garden
Chainsaw gas/oil mix ratio
Jun 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw runs, but dies when given gas.
adjust the gas and air on the two little screws on the carborator
Dec 26, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
238 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
