Question about ACCUTIME WATCH CORP. Star Wars Darth Vader Watch - Kids Light Up Rubber
My darth vader red light won't turn off - ACCUTIME WATCH CORP. Star Wars Darth Vader Watch - Kids Light Up Rubber
Seiki se50fe02 Tv will not turn on
Return it. It's defective.
Oct 22, 2014 | Seiko Watches
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
How do i change a lego watch battery?
I used this website How to Pry off Watch Backing Without Proper Tools all you need is a small screwdriver. There is a tiny tab on the back of the watch you must pry off gently, then you will probably need same screwdriver to get the battery out, again, gently There is no need to pull out the knob on the side of the watch or take off the timer ring from the face. Once you replace the battery, the back snaps back on fairly easily.
We had a c3p0 watch and the battery is an sr626sw which you must source online.
Jan 23, 2014 | Lego Star Wars Darth Vader Wrist Watch for...
Light won't go off
Try to slightly pry the light button loose. Take a fine needle that it strong and work it around the button to see if you can release it. If so,then continue to work the needle around to remove some debris. Let me know how this does.
Feb 02, 2013 | Watches
I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Apr 09, 2011 | Nixon Lodown Tide watch
Light turned off, can't get it to turn back on
There are more tha one version of your watch, so you need to go to the Nike web site to be sure that you have the correct instructions.
From what I can make out, the backlight comes on when the upper left hand button is pressed. The light will turn off after a short while, to preserve the battery
To get a copy of the instructions, go to the web site "Niketiming.com. "
Select you language and region.
On the left of the screen there is a box with a drop down menu for manuals. Choose yours and download.
Jan 17, 2010 | Nike Anvil Comold Super Deep Burgundy/Team...
My tissot watch st. steel back plate and dial case has 0.5 mm gap. after looking at the watch sideways in light i can see the gap, it seems the back plate can be further pushed inside the dial case so that...
All of the press on backs will have some degree of gap (should be able to fit a razor blade in) but .5mm sounds like far too much. Most probably the gasket is out of place or you need a new one. The gaskets in Tissot are notorius for displacing and mishaping upon a battery change. To get these special red Swiss gaskets you will need to go to a jeweler. I would call around to see who has Tissot style gaskets in stock because sending the watch out for repair will cost you at least $50 and this is an unnecessary cost.
Oct 20, 2009 | Tissot Desire Steel Large Bracelet Watch -...
How to take link out of a watch urself?
get a darth if and poke it out ut only do that if it is an ROLEX JAGUAR OR A AMANI.IT WORKED FOR ME
Jul 22, 2008 | Watches
ACCUTIME WATCH CORP. Star Wars Darth Vader Watch - Kids Light Up Rubber Logo
Top ACCUTIME WATCH CORP. Watches Experts
Ansel Alberto
Ansel Alberto
Are you an ACCUTIME WATCH CORP. Watch Expert? Answer questions, earn points and help others
