Question about Husqvarna YTA19K42 42 inch 19 HP Kohler Lawn Tractor
Is there a larger steering wheel that fits Husky YTA19k42 mower? Standard is approx 12" diameter.
I want a larger steering wheel to to make it easier to turn and help with hand/wrist arthritus problems. Standard 12" is too small. Love mower except for this.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Have you tried a steering wheel handle? Small knob that fits to a steering wheel which saves having to grip the wheel. People with dexterity difficulties use them on cars here in the UK, here's a video of one from the US
Posted on May 04, 2015
1993 Mazda 929 leather with cruise control
isnt the steering wheel adjustable?
Jul 16, 2008 | 1993 Mazda 929
Can I put 235/60R16 on 2008 chevy uplander
The stock wheel and tire is ;
wheel - 17 x 6.5 inches
TIRE - 225 60 17 702 mm diameter
If you wanted a 235 60 17 that would be ok but the tire diameter is larger by a small margin.
If you are reducing wheel size with 16 inch wheels in order to fit the 16 inch tires mentioned in your question you better make sure that the smaller diameter wheel will clear the brakes front and rear.
For a 235 tire the wheel width will need to be 6.5 inches minimum.
So if you go with ...............
wheel- 16 x 6.5 or 16 x 7 inch
TIRE - 235 60 16(as in your question)- 688 mm diameter
Provided the 16 inch wheel clears the brakes that would be OK but that tire is slightly smaller in diameter than stock but within an acceptable margin.
Make sure whatever tire you select that the tire load rating is not less than the stock tire and not less than the tire load rating stipulated by General Motors for that vehicle..
Feb 28, 2016 | Cars & Trucks
Model GT2542. How can I make it easier to steer?
A lot 0f machines have grease fitting 0n the down and up spindle and on wheel hub
Feb 11, 2016 | Cub Cadet Garden
What size tires are on 2001 buick century
20021 Buick Century Sedan - Tire Size
If you have the standard factory 15 inch (diameter) x 6.0 inch (wide) wheels then the tires fitted were size: 205/70R15 (205 is the tyre width in mm and the 15 denotes the tyre bead diameter in inches for fitting to 15 inch wheels. The R denotes the speed rating of the tire).
The tires currently fitted to the car have the size moulded into the sidewall of the tire.
However I do not know if aftermarket wheels have been put on the car and if so a different size tire from the standard factory fitment may have been fitted to the wheels.
I hope this helps.
Dec 13, 2010 | 2001 Buick Century
Where is the power steering located
Under the hood at the place where the steering axel comes from the inside is a drum-like fixture approx. 12 inches diameter and some 4 inches thick. This is the vacuum booster for the steering. It takes the vacuum from the braking system.
The power steering fluid goes into a container you also find under the hood marked usually with 'power steering' or a wheel-symbol.
Hope this helps you with your problem.
Nov 26, 2009 | 1999 Buick LeSabre
Husky rider wont turn left
CHECK THE STEERING SHAFT GEARS AT THE BASE OF THE STEERING WHEEL. I HAVE SEEN THE TEETH ON ONE SIDE BREAK OFF
Jul 29, 2009 | Garden
The factory charge is 195 oz. seams kind of high for a residential heatpump to me. i'm used to a unit holding approx 5-6 lbs. this is a 410a system.
410a system is a higher efficiency unit that has a larger outdoor coil and inside evaporator coil.also the copper line coming from outside are larger one size in diameter. thats almost 12 lbs. sounds like you have a 5 ton system
May 23, 2009 | Heating & Cooling
I need to know the diameter of a wheel bearing drum.
knock old bearing out and take it to motor factor ,easier in the end as sizes vary according to supplier for assembly line
Apr 06, 2009 | 1998 Ford Escort
Husqvarna YTA19K42 42 inch 19 HP Kohler Lawn Tractor Logo
110 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
