Question about Tablets & eReaders
My tablet will not power up. I have charged it over night and still nothing. I tried different chargers and still nothing. Help!!
  • Tablets & eR... Master
  • 3,320 Answers
It could be that you have damaged the on/off button.
It could be that you have damaged the USB charging port.
OR
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Posted on Apr 26, 2015
Brand new tablet will not turn on
Make sure it is fully charged. Hold power button down for about 10 seconds and wait if nothing comes up press power again for half a second. Still nothing? Then put it on charge, it should show that it is charging with a light of a picture on the screen. If there is no sign of charging, wait about 3 hours leave the charger connected and press the power button again for about a second and wait for it to turn on or for the picture to show it is charging appears on the screen, (make sure the charger is on and connected) . Press the power button again for another 5 seconds and wait. sometimes it takes a little while to turn on, especially if the battery is very flat. Other things to try are check the charger on another device e.g. another table or a phone if you can and try another charger on the tablet if they are compatible, (usually the same plug is o.k, check the voltage is the same. most chargers are USB 5v). It may need a more powerful charger than most small phones,. you can try plugging the USB cable into a car charger or USB 3.0 port on a computer. 2 amps is common for most tablets. Apple may be different, hard to be exact without knowing brand etc.
If all else fails see the retailer
Dec 26, 2017 | Tablets & eReaders
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Wont charge ,tries to come on while plugged in but shuts right back off?
Allow the charger to charge the battery with the tablet OFF over night. The tablet requires MORE power than the charger can provide - but the charger provides enough power to slow charge the battery. In the morning it should be fine - unless the battery no longer can support a charge.
May 18, 2015 | Maylong Android Tablet M-250
Tablet was charging and I was playing candy crush then it turned off. Hasn't turned back on since. Tried charging it but No indication that it is charging. Tried The power button and hold volume button and...
Try a different charger. The tiny wires in charging cables are delicate and break easily. You may have had the tablet connected to the charger and nothing was happening and you ran the battery till it was dead.
Feb 20, 2015 | Tablets & eReaders
My nabi tablet is charged but wont turn on
Try a different charger first, as it maybe faulty. If not the battery maybe faulty and I would purchase a new one.
Mar 16, 2014 | Nabi 2
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
Cant get my samsung tablet to turn on
Your tablet's battery is probably dead. This may be because you have a bad battery, a bad charger, or a bad charging cable. Try using a different cable first and let it charge for a few hours - even if it doesn't look like it is charging.
If the new cable doesn't do it, try using a different charger. Samsung devices are picky about what charger you use, so try to use one made for your tablet. If you don't have another charger, plug it into a PC's USB port with the PC turned on. Leave them on and plugged in over night. That should trickle charge your tablet.
If neither of those work, try holding down the power and the Volume Up buttons. Keep them both pressed until the Samsung logo/boot screen comes up - should only be a couple seconds. Once the logo comes up release the power button but keep holding the Volume Up button. That will boot you into Recovery Mode. If that comes up, it means you've got power and your tablet isn't broken, but there is something wrong with the Android OS that is keeping your tablet from powering up normally. Use the Volume Up and Down buttons to move the selection highlight to the Factory Reset option. This will wipe all the info off your tablet and put it back into a "brand new just out of the box" state. You'll lose your information on the tablet, but this should fix the boot problem. Press the power button to chose the Factory Reset option. It will take a few minutes. Once it says that it is done, select the Reboot or Restart option. It should reboot. This boot will take longer than normal, since its wiping things out. But not more than a few minutes.
Jan 02, 2014 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
76 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
