Question about Canon EOS Rebel 2000 with 28-80 lens 35mm Film Camera
How to turn Canon Rebel 2000 EOS on
Where is the turn on button located
    Sergeant:
  • Canon Expert
  • 488 Answers
Turn the camera on by turning the left-hand dial (looking from the back of the camera) to the red square marked L for "lock."
Posted on Oct 04, 2016
  • 62 Answers
SOURCE: EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
Posted on Aug 28, 2008
  • 155 Answers
SOURCE: canon rebel eos ds6041
DS6041 is the model number for Canon EOS Digital Rebel or 300D. It is a 6.3 megapixels DSLR camera from Canon.
All software and manuals available from the Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=9430
Posted on Feb 18, 2009
  • 7 Answers
SOURCE: Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Posted on Aug 22, 2009
  • 164 Answers
SOURCE: Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Posted on Aug 25, 2009
  • 30 Answers
SOURCE: my canon eos rebel xt 350d wont focus
change your manual settings
Posted on Oct 11, 2009
Canon EOS Rebel GII With 35-80 Lens 35mm Film Camera shutter
In manual mode you should be able to change the shutter speed simply by turning the main dial (the thumbwheel located near the shutter release button).
Jun 28, 2012 | Canon EOS Rebel G-II 35mm SLR Camera
Tip
Canon Rebel XS Firmware Update MAC Models: Canon EOS Rebel XS / Canon EOS 1000D...
Solves: BUSY Error & Error 99
Doesyour Canon EOS Rebel XS / Canon EOS 1000D suffer from either of thefollowing error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which theLCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. Themessage, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears onthe camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from theactual language setting.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems.
To download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
__________________________
Follow this link to download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Follow this link to download a pdf version of the firmware installation instruction guide.
Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
on Apr 15, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Tip
Canon Rebel XS Firmware Update WIN Models: Canon EOS Rebel XS / Canon EOS 1000D...
Does your Canon EOS Rebel XS / Canon EOS 1000D suffer from either of the following error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
To download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Canon EOS 300 user info, functions, no user manual
The EOS 300 is called the EOS Rebel 2000 in some parts of the world. You can download the Rebel 2000 manual at
http://downloads.canon.com/cpr/software/camera/EOS_Rebel_2000_manual.pdf
Sep 20, 2011 | Canon Photography
How do i turn off my canon rebel 2000 eos
Turn the command dial to the "L" position to turn off and lock the camera.
If you need a manual, you can download one from
http://butkus.org/chinon/canon/canon_eos_rebel_2000_300/canon_eos_rebel_2000_300.htm
Aug 27, 2011 | Canon EOS Rebel 2000 35mm SLR Camera
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon rebel 2000 EOS pictures are cut off by 1/3
shutter problem, cut off is part not exposed,replace the shutterunit.
Mar 07, 2010 | Canon EOS Rebel GII with 35-80 lens 35mm...
Flash on a canon rebel 2000 eso
Just push the flash back and it locks ,...... thats flash off
Oct 14, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Canon EOS Rebel 2000 with 28-80 lens 35mm Film Camera Logo
296 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
