Question about Jensen VM9410 Car DVD Player
K was working great before Radio works but now will not take in DVD's or CD's. Cant figure it out what happened. Thanks
Hi i have a eonon e1015 when trying to play a dvd it saying no disc and the same with music cd.sd card works fine radio works what could be the problem I think its laser problem thanks.
I just installed a new eonon 1015 and i cant paly any CD or DVD, it seas that there is no diskt....i think i have installet correctly, but there is another orange cable wich i didnt know where to connect...can you hel please ?
Jun 29, 2011 | Car Audio & Video
Pioneer xv-hdt520 stereo dvd/cd player cant get it to play cd,s works fine on the dvd part of it and all discs are read by the same reader it just tries to start then boots the cd out no matter which...
I would guess this model is over two years old. not sure how much you paid, but target sells a decent surround sound blue ray system for just under 300. i got it. it works great, streams netflix movies an even has an internet radio system in it.
if you dont wanna do that, and have made sure that you have tried brand new cds, another option is to play cds on a cheap cd player hooked into your surround sound. it can go in any input on the back with an adaptor you can buy at radio shack, or many of them have an input in the front.
they used to make a cd lens cleaner, not sure if they still exist. it was a tiny brush hooked onto a cd that you put in and it cleaned up the lens.
bottom line is that it makes little to no sense to me that it would play dvds and not cds. i would assume that they both use the same lens to read the device.
Nov 22, 2010 | Pioneer Audio Players & Recorders
I have a valor ida700w dvd cd car stereo in my truck and the radio works but the dvd cd player will not play. can you troubleshoot my problem please
FYI..... for any one with a Valor IDA-700w.
The dvd/cd drive assembly was poorly designed.
the clamp that secures disc as it rotates mounts
on one side with a plastic pivot,fine,but the other side
uses a longer metal arm that also has the clamp spring.
The spring exerts too much pressure on the arm and cracks
its plastic anchor.
I repaired mine with JB weld and it plays cds but will not
play dvds,just hunts and hunts or skips.
Oh well,radio plays great-by the way, an undocumented feature
of the unit is that it has a Zoran decoder chip for Dolby Digital
and DTS-too bad drive is inferior.
DTS cd discs play great when it works!
Aug 08, 2010 | Valor IDA-700W Car DVD Player
When i want to change from radio to cd function on my head unit nothing happens, the radio works i think it happened when my battery was flat and had to get aa out to restart me, cant be the code as radio...
try pressing the reset switch or disconnecting power to the radio for a few minutes. sometimes jumping the battery sends a voltage spike to the radio and locks up the microprocessor.
Feb 25, 2010 | Alpine CHM-S630 6-Disc CD Changer
DVD's will no longer play
try blowing or its how you swipe your cds you should swipe up and down by a cd cleaner that might work
Apr 26, 2009 | Samsung DVD-V4600 DVD Player/VCR
Jvc
will have a another look around for you but you could start here
http://4jvc.co.uk/cgi-bin/pne.pl?display=entry&brand_id=2158&f-10=%20JVC%20KW-S601%20car%20stereo
see if they can assit as well , i i find one i will post back for you, good luck .
riz.
Nov 20, 2007 | Car Audio & Video
NOT RECIEVING SOUND FROM ALL SPEAKERS WHEN PLAYING CD/DVDS
CANNONT RECIEVE SOUND FROM THE FRONT N REAR SPEAKERS WHEN PLAYING A CD/DVD. THE RADIO AUTOMATICALLY PLAYS THROUGHTOUT THE CAR. WHEN SRC DVD/CD IS SELECTED NO SOUND EMERGES. SO I PUT ON THE DUAL ZONE. AND THE ONLY WAY TO HAVE SOUND IS TO HAVE ONE ZONE TUNER, AND THE OTHER DVD. WHEN I REVERSE THEM OF COURSE THE SOUND WILL SHIFT EITHER FRONT OR BACK. IF U CAN HELP ME FIX THIS AND RECIEVE SOUND FROM ALL SPEAKERS WHILE CD/DVD anPLAYING I WILL APPRECIATE IT. THIS IS COUPLE MONTHS NEW. IT WORKED ONCE OR TWICE IDK HOW THOUGH. AND NOW I'VE TRIED IT ALL BUT STILL CANT FIGURE IT OUT. i went into the zone control and turn off the rear and i still have nothing. pleease help
Oct 08, 2007 | Kenwood KVT-617DVD Car DVD Player
Dvr-106d -Windows freezes,cant read new Dvds
if you have had two drives with the same problem i would check the ide cable and swap to another one if you have a master and slave twin connector ide cable, or even try the dvd rom on the same ide cable as the hard drive as you know that that ide connector and cable is working, unless you have a SATA hard drive in which case you won't be able to; but will still have a spare ide channel connector to try the drive on.
Jun 26, 2007 | Pioneer (DVR-106D) DVD±RW Burner
Change DvD for HDD
the same thing is happening to me i cant figure it out!!!
Mar 02, 2007 | QPS Que! SuperDrive DVD-RW Burner
Jensen VM9410 Car DVD Player Logo
63 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
