What is the meaning of(configuration error) & How can I solve it?
  • Harrie Apr 27, 2015
    Hi Amir hajari, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? on what? brand? model? OS?
Vaio vgn c13g b
Hi there, copy the error code and google for solution.
Solution Steps:
The device is configured. (Code 26)
Restart the computer to complete the installation.
Solution button: Restart Computer
This code means that a device was not loaded. There may be a problem with the device driver or does not have all the drivers installed.
To resolve this error, follow the recommended solution. If this does not work, use the Device Manager to remove the device and then run the Add New Hardware Wizard in the Control Panel. If the error code persists, contact the hardware manufacturer or consult the Microsoft Software Library to obtain an updated driver.
Best Regards
Dec 18, 2013 | Sony Computers & Internet
My fluke 45 multimeter displays error 6. how can i solve it?
This is explanation on Error 6 from Service Manual:
EEROM (A1U5) meter configuration corrupted or EEROM not initialized. At power up, A1U6 reads CRC from EEROM (A1U5) location, then reads configuration data from another location in EEROM, calculates an algorithm to compare to the CRC. If an error is determined, the meter configuration is set to factory default and Error 6 is displayed.
You can find service manual with troubleshooting procedure here: http://www.fluke.com/Fluke/usen/Support/Manuals/default.htm?ProductId=56082
Aug 13, 2013 | Fluke 45 Dual Display Multimeter
My computer will not accept my trio media player V 2, it tells me windows error 43
This means that your windows have some configuration problem.
This sort of problem can only be solved by installing a new windows
Dec 17, 2011 | Mach Speed Trio Audio Players & Recorders
Failure of server APACHE bridge What does this mean?
Hi!
First of all Apache Bridge is a Plug-in which has the ability to Integrate, Application Servers such as Weblogic (Oracle's component) with the Apache servers (http or web servers).
Before solving the issue you have to specify with what component or software this error occurred. This issue is common if you have used Weblogic/ Weblogic plug-ins.
This error occurs when the Apache server is unable to communicate with Weblogic Server if you are using one.
  1. So first you must ensure Weblogic servers/plug-ins have been properly setup/configured!
  2. You have to check Apache error logs if you use an internal web server.
  3. If there are errors, you have to configure Apache properly.
  4. If you are using WL clusters configure and test.
  5. Apache logs are located in /apache/logs. Check logs under Managed Instance or Admin Server.
  6. Make sure your plug-ins are compatible with Apache.
  7. If you are using Weblogic, please read the manual at Oracle.
These are highly technical issues and Fixya experts spend their time to provide the best possible answer. So please be kind enough to rate and or pay if their is a bid set up. That will encourage our experts.
Sep 03, 2010 | Computers & Internet
I click on the game but "the game could not be started.(80020o321)" coming out.how to solve this?
Error 800200321 means 'No such device',this is because you have no such configuration on your PSP.Just go to recovery menu,go to configuration and make sure that No UMD is disabled. Now put the UMD and run the game.
Jun 14, 2010 | Sony PlayStation Portable (PSP) Console
When I turn on my computer the first thing I see is Sony Ericsson error in configuration. This does not appear on my 'phone and does not seem to affect anything but I just want to know what it means please...
This might be some failed software link. You can find these softwares link on start up at Start->All Programs->.Startup in startup remove any entry that looks like Sony Ericsson.
Also, if XP you can go to run and type "msconfig" and hit enter - on System Configuration Utility-. goto "Startup" tab and remove/uncheck any entry that matches error you receive frequently after booting up. This should solve the prob
May 13, 2010 | Computers & Internet
Blue screen error
Hi
Just boot in safe mode or Last Good configuration and then go to windows START button there take MY COMPUTER>>ADVANCED>>START UP AND RECOVERY>> Disable memory dump here .Your blue screen problem will be solved
Thank U
Please rate me as it wil cost u just one click
Oct 23, 2009 | Acer Aspire 4315 Notebook
Configureation error
Take it back to the shop - there are 3 parts to the firmware in thoses phones:
1) Main firmware
2) File system
3) Custom pack
The "configuration error" message means that the custom pack wasn't loaded - and as a result the startup code can't figure out how to configure the phone.
If the old CDA is still in the phone, then you can try using the update service software on the SE website - but that often fails to identify the phone when it's in the state that your phone is.
Jul 02, 2009 | Sony Ericsson K750i Cellular Phone
How to solve no cassette with paper of the size reguested
Did u mean that when printing, " no casette with paper" error pop up?
Then u need to make sure u configure the correct cassette paper size on your printer driver.
May 26, 2009 | Toshiba e-Studio163 Copier
Novell dsrepair
625 errors ALWAYS mean that there is a break in communication, which can also mean they just can't resolve or find the address to the server they are trying to connect to, even if its on the same subnet. You need to ensure that all systems can communicate via simple pings, then configure SLP for even better results.
Nov 02, 2007 | Novell Advanced Network Management...
k24674
jasbo
jasbo
